Unraveling the Mystery: Solving ln(ln(ln(ln x+4))) = e with Expert Help
  • Context: Graduate
  • Thread starter Thread starter sunny86
The discussion focuses on solving the equation ln(ln(ln(ln(x + 4)))) = e. The solution is derived by eliminating logarithms through exponentiation, leading to the expression x = e^(e^(e^(e^e))) - 4, which approximates to 5.14843556 × 10^23. However, further calculations suggest a more accurate approximation of x is closer to e^(5 × 10^1000000). The conversation also touches on the concept of factorials, specifically explaining why 0! = 1 using the Gamma function.
  • Understanding of logarithmic functions and their properties
  • Familiarity with exponentiation and its applications in solving equations
  • Basic knowledge of factorials and the Gamma function
  • Experience with mathematical software or calculators for large number computations
  • Study the properties of logarithmic functions in depth
  • Learn about the Gamma function and its applications in advanced mathematics
  • Explore numerical methods for approximating solutions to complex equations
  • Investigate the behavior of exponential growth in mathematical contexts
Mathematicians, students studying advanced calculus, anyone interested in solving complex logarithmic equations, and those exploring the applications of the Gamma function.
sunny86
Question : Need your help.
Can anyone please help me to solve this problem..please..
ln(ln(ln(ln x+4 ))) = e
Thanks a lot...
I'm slightly confused...are you asking why 0!=1, or are you asking what the solution for "x" is in the problem ln(ln(ln(ln [x+4])))=e? In the case of the former, use that link. In the case of the latter, all I did was eliminate logarithms by using each side as a power of "e." ln(ln(ln(ln [x+4])))=e turns into e^[ln(ln(ln(ln [x+4])))]=e^e, which is really ln(ln(ln [x+4])))=e^e and so on until you end up with ... well, I can't get this to format correctly, but the way I have it pictured in my head, it's a stairstep of 5 e's {e to power e to power e to power e to power e...so, I guess that makes it e^(e^(e^(e^(e))))}. Hm...I haven't slept in awhile, can someone verify me?
Please don't edit your posts to ask new questions. Just start a new topic.
cookiemonster
Yep your right, the answer is:
x = e^{e^{e^{e^e}}} - 4
x \approx 5.14843556 \cdot 10^{23}
Ok..thank you..
I am sorry about the mistake i made..i am soory.
Are you sure about that?
That value of x certainly doesn't work in my calculator, or on Mathematica.
No I am most defintly not sure, but I imagine it would not be very accurate for the orriginal equation. I couldn't find my calculator so I used Google's internal one, I'll have a look around and get back to you.
Yeah the approximation was WAY out. Service to say my calculator couldn't work x out but after a bit of messing about with the formulae to do some trial and error, x is far closer to:
x \approx e^{5 * 10^{1000000}}
So it is big lol. (Again I'm not 100% sure I am right but I am more confident than last time).
Edit: I did a little test to see if I was right. My thought was:
\ln \ln \ln \ln x \approx e
Therefore if my answer is right:
\ln \ln \ln \ln e^{5 * 10^{1000000}} \approx e
\ln \ln \ln 5 * 10^{1000000} \approx e
\ln \ln [1000000 \ln 50] \approx e
I put this into my calc and got:
\ln \ln [1000000 \ln 50] = 2.71995 \ldots
I too tried Google but found it didn't go far enough. Zurtex, I think you got your brackets wrong. I say this because I got your answer when I got my brackets wrong. The answer is too big to express as a power of 10. So, I'm sure the point of the question is not to be to write the number in decimal notation.
Hiya.
If you're asking why 0!=1, then here is the answer.
Typically, at high school level, you are told that a factorial is simply the product of all integers down to 1 (e.g. 6!=6*5*4*3*2*1) and that 0! is "defined" to be equal to unity, right?
That's all well and good for the nonnegative integers; but what if we want to find, say, (-3)! or (1/2)!? The recursive definition doesn't work!
That's where GAMMA FUNCTIONS (\Gamma(n)) come in! Basically, it can be shown that
\\\Gamma(n-1)=\int^{\infty}_{0}x^{n}\exp(-x)dx=n!
for ALL n larger than -1. (The integral is improper for -1<x<0, but can be shown to converge there.) So, punching n=0 to our new definition for n!, we get
\Gamma(-1)=\int^{\infty}_{0}\exp(-x)dx=1=0!;
i.e. 0!=1. (QED)
In general,
\Gamma(n-1)=n!;
it can also be shown that
\Gamma(n+1)=n\Gamma(n), or \Gamma(n)=(1/n)\Gamma(n+1);
i.e., we have a recursive definition for gamma functions. (Note that this means that the gamma function of any integer less than or equal to zero is infinite; that is, the factorial of a negative integer is infinite.) Also, it can be shown that
\Gamma(1/2)=\sqrt{\pi}.
Gamma functions are usually tabulated between 0 and 1; using the recursive formulas above, you can then find, say,
(-3/2)!=\Gamma(-1/2)=2\Gamma(1/2)=2\sqrt{\pi}.
"Mathematical Methods In The Physical Sciences" (2nd ed., published by Wiley) by Mary Boas explains this beautifully. (I strongly recommend it: an absolute bible to me during my university years!)
Hope that helps!
dannyboy :smile:
