Unstretched Spring and Angular Velocity Problem
7 replies · 8K views · last reply
BitterSuites
[SOLVED] Unstretched Spring and Angular Velocity Problem
A disk of mass 73 kg is held by a spring of unstretched length 88 cm and stiffness constant 430 N/cm, and rests on a frictionless table. It is then orbited in a circle at angular velocity .675 rad/s.
By how much is the spring stretched? Answer in units of cm.
After a bit of derivation, I came up with x = r/((k/mw^2)-1).
r = 88
k = 430
m= 73
w = .675
It does not seem to work out. Am I being to complicated about it? Any help/hand-holding is greatly appreciated.
Force acting on the disc in circular motion== mv^2/r
Now use hook's law to calculate extension..
Looks good to me.
r = 88
k = 430
m= 73
w = .675
Make sure you are using standard units. Express lengths (and k) in terms of meters, not cm.
Thanks for the catch on conversion. I changed length to .88 and K to 4.3, getting an answer in m. I then converted it to cm but the online system still says I am incorrect.
I can't use mv^2/r because I don't have v. That is why I did that insane derivation.
Or am I wrong?
I think I'm a few baby steps away from having this.
BitterSuites said:
I changed length to .88 and K to 4.3...
Redo that last one. :wink:
Uh oh. Did I go the wrong way with it? 43000N/m?
Oh, thank you so much *sighs in relief*
Converting correctly makes the problem work. Who knew? :D
