UP.2.33 The jumping flea problem
  • Context:
  • Thread starter Thread starter karush
7 replies · 4K views
karush
MHB
a. If a flea can jumps straight up to a height of 0.440m.
what is the initial speed as it leaves the ground.
b. For how much time is it in the air?
ok I am sure we use this equation
$$x=x_0+v_o^t+\frac{1}{2} at^2$$
I watched another YT on this but it got to much complication
better just to come here
Mathematics news on Phys.org
Apart from YouTube, do you also have a textbook? What does that say?
(I am asking because I am rarely able to understand something from a video that I did not understand previously already.)
I think you mean $v_0t$ in the equation for $x$?
In a drawing, let the vertical axis be the $x$ axis, with upward = positive. The initial $x$-position $x_0 = 0$.
What do you choose for the acceleration $a$? What is the sign of $a$?
Now note that at the maximal $x$-position the velocity equals zero.
How do you obtain an expression for the velocity from the expression you have given?
I got that from the YT vid
the text is University Physics
but equation the is also form 2-12 on their eq list
I not in a class just doing this on my own.
(a) $v_f^2 = v_0^2 -2g \Delta y$
At the top of its trajectory, the flea’s velocity is zero and $\Delta y = h_{max}$ ...
$v_0 = \sqrt{2g h_{max}}$
(b) calculate the time it takes for the flea to reach the top of its trajectory, $h_{max}$, and double it ...
$v_f = v_0 - gt \implies t = \dfrac{v_0}{g}$
total time, $T=\dfrac{2v_0}{g} = \dfrac{2\sqrt{2gh_{max}}}{g}$
ok the textbook answers to this is
a. 2.94 m/s
b. 0.599 s
I'll see if i can plug into get em
$\displaystyle 0.599s=\frac{2\sqrt{2gh_{max}}}{g} $
if $g=-9.8$ and $h_{max}=.44$
$$x=x_0+v_ot+\frac{1}{2} at^2$$
Well, since the "up to a height of 0.44m" is the height above the starting height, you can take $x_0= 0$. Then $x= v_0t+ \frac{1/2}at^2= \frac{1}{2}a(t^2+ \frac{2v_0}{a}t)$ is a quadratic and we can "complete the square": $x= \frac{a}{2}\left(t^2+ \frac{2v_0}{a}t+ \frac{v_0^2}{a^2}- \frac{v_0^2}{a^2}\right)= \frac{a}{2}\left(x+ \frac{v_0}{a}\right)^2- \frac{v_0^2}{2a^2}$. "a" here is negative so that this is an "upside down" parabola. When $t= -\frac{v_0}{a}$ it takes its maximum value $-\frac{v_0^2}{2a}$.
For (a), assuming this is on the surface of the earth, set a= -9.81 and solve $\frac{v_0^2}{19.62}= 0.440$ for $v_0$.
For (b), since a parabola is symmetric about its midline, take t equal to twice the "t" above, $-\frac{2v_0}{a}$.
2(2.94)/9.81=.599
For part a), we could use conservation of energy...initially the flea has kinetic energy, and then when it reaches the apex of its jump, it has potential energy:
$$\frac{1}{2}mv_0^2=mgh$$
Solving for $v_0$, we obtain:
$$v_0=\sqrt{2gh}$$
For part b), we could write:
$$h(t)=\frac{t}{2}\left(2v_0-gt\right)$$
We are interested in the non-zero root, hence:
$$t=\frac{2v_0}{g}=\frac{2\sqrt{2gh}}{g}=2\sqrt{\frac{2h}{g}}$$
