Use algebra to find the x and y intercepts , for a quadratic equation
The discussion focuses on finding the x-intercepts and y-intercept of the quadratic equation y = -x^2/5 + x/5 + 6. Participants clarify that the y-intercept is found by substituting x = 0 into the equation. To find the x-intercepts, they agree on the need to set y = 0 and clear the fractions, leading to the equation -x^2 + x - 30 = 0. After multiplying by -1, the quadratic can be factored to (x + 5)(x - 6). The conversation emphasizes the importance of maintaining the correct signs in the equation.
duggielanger
Use algebra to find the x-intercepts and y-intercept of The graph of y=-x^2/5+x/5+6
this is a parabola.
y=-x^2/5+x/5+6
Find the y-intercept , which is substitute 0=x into the equation to find the answer , done that .
The problem I have is where to start to find the x-intercept , I know that y=0 so I now have x^2/5+x/5+6=0 , but believe I can't now factorise this equation and will have to first clear the fractions first . Is this the right place to start.
duggielanger said:
Use algebra to find the x-intercepts and y-intercept of The graph of y=x^2/5+x/5+6
this is a parabola.
y=x^2/5+x/5+6
Sounds a good place to me. What do you then get? Have you learned e.g. completing the square, or the quadratic formula yet?
Not answered the question yet ,and not done them yet they are coming up in the section.
Will try and find the answer in a bit and post my results .
Hint: since one side of the equation=0, you can easily multiply both sides by 5, and then -1...
this is a parabola.
y=-x^2/5+x/5+6
Note that you've dropped the minus sign on the coefficient of the x^2 term the last time you wrote that (in bold). That minus sign is all-important. Without that, you don't have an x-intercept!
yeah thank you for that i will remember the minus sign
Once you have done what e^pi i + 1= 0 suggested, multiplying the entire equation by -5, you will have a quadratic equation with integer coefficients that is easy to factor.
Ah right think I have it now , multiply by the least common denominator, which is 5, which leaves me with -x^2+x-30=0 and the by -1 to get x^2-x-30=0 and then factor to get (x+5)(x-6).
Thank you everyone
No, you get -x^2+ x+ 30 but then your next is correct:
Thank you everyone
Yes, that is correct.
