Use Archimede's Spiral For Accelerate An Object.
lba
Hi,
Is it possible to help to accelerate an object with an Archimede Spiral ? We can apply a force F perpendiculary to the spiral, like this if we want to turn the spiral in its center we don't need energy. If we want to accelerate an object near the spiral, we apply a force F to the spiral, the spiral apply the same force in the contrary direction. The object accelerate. The spiral can turn without energy if the force F is perpendiculary to the surface (it's possible with an Archimede Spiral). Like the object accelerate, if we want always a contact between the spiral and the object, we need to accelerate the spiral, but this don't require more energy. In this case what is the energy need for accelerate the object ? It is the same without spiral ? Why ?
  • Diagram of a green rectangle labelled Object to move, with arrows labelled F pointing up and down where it touches the top of a red Archimedean spiral; annotations explain the object accelerates and the spiral turn needs no energy.
The spiral is not a circle, so you can't have F perpendicular to it in this arrangement. So there will be some work of F, and energy will be consumed.
You're right but if I use 4 centers like the figure show, it's not possible to turn the spiral without energy ? It's an approximation and a little energy is needed but less I think.
  • Multicolour spiral curve winding outward from a small central loop, with colour changing from red to green to cyan around the coil, and four small coloured circles near the centre.
If the object to move is on a frictionless surface, then, theoretically, you need an infinitely small energy and infinite time to move the object to any distance, with or without the spiral. If, however, there is friction, then the force of friction will do work that is proportional to the mass of the object and the distance to move, and you cannot spend less energy than that, again, with or without the spiral.
All in all, the spiral gives you nothing in terms of energy.
