Use exponential notation to form a+ib
18 replies · 3K views · last reply
thatguythere
Use exponential notation to write (√3-i)(1+i√3) in the form a+ib.
Let (√3-i) = z1
r1=|z1|=√((√3)2-i2)
=√(3-1)
=√2
Therefore,
√3=√2cosθ and -1=√2sinθ
cosθ = √3/√2 and sinθ = -1/√2
θ= arcsin(-1/√2)
θ= -∏/4
z1 = √2(cos(-∏/4)+isin(-∏/4))
Let (1+i√3) = z2
r2 = |z2| = √(12+(i√3)2)
= √(1+(1(3)) <-- I am very uncertain about this step
= √4
= 2
Therefore
1 = 2cosθ and 3 = 2sinθ
cosθ = 1/2 and sinθ = 3/2
However,
θ=arcsin(3/2) does not compute which leads me to believe that (i√3)2 = 3 is incorrect. Any help is appreciated. Thank you.
Let (√3-i) = z1
r1=|z1|=√((√3)2-i2)
=√(3-1)
=√2
Therefore,
θ= arcsin(-1/√2)
θ= -∏/4
Let (1+i√3) = z2
= √4
= 2
Therefore
However,
What is i2 ?
i2 = -1
However if I plug that in, I get this.
r2 = |z2| = √(12+(i√3)2}
= √(1+(-1(3))
= √-2
Which still does not compute.
thatguythere said:
i2 = -1
= √(1+(-1(3))
= √-2
|a+bi|=sqrt(a^2+b^2).
Ah, right. This leads me to another question. Do I use the "1" from i and eliminate the sqrt3, or treat it as (sqrt3)i and use the resulting 3? I would guess the latter.
I'm not sure what you are asking. If z2=1+i*sqrt(3) then a=1 and b=sqrt(3). sqrt(a^2+b^2)=sqrt(1+3)=2.
That is what I was asking and what I thought. Thank you. Now let's see if I can wrestle this into exponential form.
Good. Your probably know using exponential form is a complete waste of time, right? You could just multiply (√3-i)(1+i√3) out and be done with it. But if that's what the ask you to do then that's what you should do. It'll be easy to check your answer.
Well, the problem states "Use exponential notation to write (√3-i)(1+i√3) in the form a+ib." Have I been wasting my time?
Not if the problem forces you to do it that way. I'm just saying you can easily check your answer by doing it the simple way.
z1 = √2{cos(-∏/4)+isin(-∏/4)} = √2ei(-∏/4)
z2 = 2{cos∏/3+isin∏/3) = 2ei∏/3
z1z2 = 2√2ei(-∏/4)+i∏/3
=2√2ei∏/12
So far so good?
=2√2ei∏/12
So far so good?
z2=2*exp(i*pi/3), that's good. z1 isn't. You might be rehashing some of your old bad stuff into that one.
thatguythere said:
z1 = 2{cos11∏/6+isin11∏/6}
= 2ei11∏/6
I would have said 2exp(-i*pi/6), but sure, that's the same as 2exp(i*11pi/6). Think you are almost there.
z1z2 = 2*2ei11∏/6+i∏/3
= 4ei13∏/6
4{cos13∏/6+isin13∏/6} Trig confuses me, so let's see.
4{-cos∏/6-isin∏/6}
4(-√3/2)-(i/2)
-2√3-2i
= 4ei13∏/6
4{-cos∏/6-isin∏/6}
4(-√3/2)-(i/2)
-2√3-2i
4*exp(13*pi/6) is correct. I guess trig does confuse you. cos(13*pi/6) isn't equal to -cos(pi/6). Why would you think that?
I don't know what I did there. Does it instead behave the same as ∏/6? Making my answer
2√3+2i?
2√3+2i?
Sure, multiply out (√3-i)(1+i√3) to confirm that.
