Use the Node Voltage method to solve
The discussion revolves around a circuit analysis problem using the Node Voltage method, specifically aiming to find the voltages VCB and VDG. The original poster has established a ground reference and outlined equations based on Kirchhoff's Current Law (KCL) and Ohm's Law, but is seeking further guidance to formulate a complete set of equations for simultaneous solving.
  • Participants discuss simplifying the circuit by replacing series and parallel resistances with their equivalent values. There are inquiries about the correctness of the simplifications and the relationships between node voltages, particularly questioning the values of VA and VB.
Some participants have provided guidance on simplifying the circuit and have confirmed certain relationships between node voltages. The discussion reflects a mix of attempts at solving the problem and clarifying the setup, with no explicit consensus reached on a final solution.
There are indications of potential confusion regarding the values of certain node voltages and the implications of the circuit simplifications. The original poster has noted specific relationships, such as VD being twice VC, which may influence the overall analysis.
cavalieregi
From the above circuit find VCB and VDG
Know Data:
VE = 0 (ground)
KCL and Ohm's Law are used in Node Voltage Method.
I decided I would determine the node voltages then work out VCB and VDG afterwards.
1. KCL and Ohm's law at Node C
## 15 + V_F + V_D = 3 V_C## -(1)​
2. Super Node at EG
2.1 KCL and Ohm's law for all currents entering
## 2(V_F - V_G) = 2 V_E - V_D - V_B##
## 2(V_F - V_G) + V_D + V_B = 2 V_E## -(2)​
2.2 Potentials at Nodes E and G
## V_G = -5V## -(3)​
3. KCL and Ohm's law at Node D
## V_C = 2 V_D## -(4)
This is as far as I got I am unsure what to do next so I can get 5 equations so they can all be solved simultaneously.
The problem highly simplifies if you replace the series and parallel resistances with their resultants.
So if I replaced the two between F and G, and the one between C and F right?
Yes, and the two resistors between C and E, and also the two resistors in series with the 15 V battery.
In the simplifed circuit, you can find the voltage VC with the node voltage method . Knowing Vc, you can calculate the currents, and knowing the currents, you can determine all node voltages.
Simplified Circuit.
This is what I have done. Not sure if correct?
How would I find VB? Is VA really = 15V.
NOTE: VD = 2VC so it can be eliminated.
cavalieregi said:
Simplified Circuit.
Actually I think I have it just wait.
Simplified Circuit.
I think I have made a mistake somewhere.
NOTE: VB is meant to be negative at end where = 76.67V
Your solution is very complicated...
The circuit is equivalent with the one in the picture, except B and D nodes disappearing. You can solve it for Vc.
The circuit is equivalent with the one in the picture, except B and D nodes disappearing. You can solve it for Vc. View attachment 75156
Thanks I have now managed to solve this!
cavalieregi said:
Simplified Circuit.
No, VA is not 15 V, as we count the potential with respect to E. VA-VB=15 V
I figured Va = Vb + 15 and it worked!
Splendid! What did you get for VC?
Have you tried to solve the problem also with the very simple equivalent circuit?
I got VC = 2.5 V
Using the equivalent circuit, the node equation for the currents at C is: ##\frac{15-Vc}{2}=\frac{Vc}{2}+\frac{Vc-(-5)}{1.5}## You need only this equation to solve for Vc, which is the same you got.
  • · Replies 18 ·
