Using a set of data to determine values on the same line
  • Context: Undergrad
  • Thread starter Thread starter ka0ttic
    Data Line Set
This discussion focuses on developing an RF loss calculator to determine insertion loss over a given length of cable or through a passive device at specified frequencies. The user, Aaron, seeks guidance on using manufacturer data for a 2-way coax splitter (rated 5-1000MHz) to calculate insertion loss at non-listed frequencies, specifically at 300MHz. Key techniques mentioned include regression analysis and linear interpolation, with an emphasis on understanding the slope for accurate calculations.
  • Understanding of RF loss calculations and insertion loss metrics
  • Familiarity with regression analysis and statistical methods
  • Knowledge of linear interpolation techniques
  • Basic grasp of plotting data and analyzing curves
  • Research "linear interpolation methods for RF calculations"
  • Study "regression analysis techniques in statistics"
  • Explore "non-linear data fitting methods for RF loss"
  • Learn about "plotting data using software tools like MATLAB or Python"
Engineers, RF technicians, and data analysts involved in RF design and performance optimization will benefit from this discussion.
ka0ttic
Hey everyone,
Firstly, I apologize if there is a more suitable forum. I think this would be considered a calculus problem, but I'm not sure. I'm trying to develop a RF loss calculator for work that can calculate RF loss over a given length of cable or through a passive device at a given frequency. My math is not that great, so I'm hoping you guys can put me on the right track.
As an example, here's a manufacturer data sheet for a 2way coax splitter (rated 5-1000MHz):
Code:
Frequency (MHz)                             Insertion Loss (dB/mV)
5                                                   4.2
40                                                  3.8
50                                                  3.8
450                                                4.3
550                                                4.4
750                                                4.6
870                                                4.9
1000                                              5.5
I would like to figure out the math that would allow me to find out the insertion loss based on any given frequency using that data to find it. For example, if I wanted to find out what the insertion loss would be at 300MHz, the data sheet goes from 50-450MHz with nothing in-between. Obviously, with the small amount of change, I could guess and be close enough, but if I'm going to write an application to do the math, I want it to be as accurate as possible.
I know that slope is involved but I'm not really sure about calculating slope for a curved line. I also am unsure of what I need to do once I figure out the slope to determine the insertion loss for a given freq.
Is anyone able to point me in the right direction? I'm totally for learning this myself, but I've had a hard time trying to do that, just because I don't necessarily know all the correct math lingo to research it.
Thanks for any help,
Aaron
What you need is regression analysis and someone with good knowledge of Statistics and experiment design.
Are you willing to use a different formula for each different type of data table?
If you plot the data in a table and it looks approximately like a line then you can use "linear interpolation".
If you encounter tables where the plot is very different than a line then there are other methods. At a glance, the example you gave looks non-linear. If you post some plots of type of data you encounter then perhaps someone will suggest good methods to use.
  • · Replies 76 ·
  • · Replies 64 ·
  • · Replies 28 ·
25K
