Using cin to Read Integers in Formation a@b in C++
  • Topic: C/C++
  • Thread starter YoungPhysicist
    c++ input
7 replies · 2K views · last reply
YoungPhysicist
Insights Author
if I want to read to integer a and b and they are in a formation of a@b, I CAN SIMPLY USE
scanf(%d@%d,&a,&b)
to read the input. But how should I do that in c++(with cin)?
I would get familiar with string methods and read the input into a string that you can then parse anyway you want.
As an example, you might want to input time values allowing either a decimal format or the hour:minute:second format. String methods would give you the flexibility you’d need to parse the input.
Agree. Especially since one can try parsing one way, test for an error, and parse another way if necessary.
Here's a tutorial on string methods in C++:
https://cal-linux.com/tutorials/strings.html
It mentions regular expressions and using the Boost library too. Regular expressions can dice up some pretty fancy string formats and is a useful skill for using GREP, SED or AWK commands in shell scripts (or not) under Unix / MacOSX / Linux.
Is the <boost/regex.hpp> it mentioned in the standard library?
strtok() comes to mind...
