Using crontab to clone private GitHub repo and run lualatex on Ubuntu
  • Thread starter Thread starter Wrichik Basu
    Linux
16 replies · 4K views
My distro is Ubuntu 22.04.2 LTS. I am trying to set up a cron job that will clone a private GitHub repo via git every hour, run lualatex, and save the compiled PDF to Google Drive. I have written a script for this purpose:
[CODE lang='bash' title='myscript.sh']#!/bin/bash
cd /home/wrichik-basu/opt/cron_scripts
if [ ! -d "./temp" ]; then
mkdir temp
fi
cd temp
if [ -d "./myrepo" ]; then
rm -rdf ./myrepo
fi
echo "Cloning repo..."
git clone -q --depth=1 <SSH_Link_to_private_GitHub_repo>
cd myrepo
echo "Running LuaLaTeX #1..."
lualatex -interaction=nonstopmode formulae_main.tex >/dev/null
status=$?
if [ $status -eq 0 ]; then
echo "Running LuaLaTeX #2..."
status=$?
echo "Copying generated PDF to Google Drive..."
cp ./main.pdf /path/to/Google/Drive/mount
fi
fi
echo "Cleaning up..."
cd ../..
rm -rdf ./temp[/CODE]
The script works fine when I run it from the terminal.
The cron job is set up as follows:
Bash:
10 */1 * * * /full/path/to/script/myscript.sh >/dev/null
This throws the following error, that I can retrieve via postfix:
[CODE lang="bash" title="Error"]MIME-Version: 1.0
Content-Type: text/plain; charset=UTF-8
Content-Transfer-Encoding: 8bit
X-Cron-Env: <SHELL=/bin/sh>
X-Cron-Env: <HOME=/home/wrichik-basu>
X-Cron-Env: <LOGNAME=wrichik-basu>
Message-Id: <redacted>
Date: Wed, 7 Jun 2023 11:10:03 +0530 (IST)
Status: R
X-IMAPbase: 1686118612 3
X-UID: 1
git@github.com: Permission denied (publickey).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
/full/path/to/script/myscript.sh: line 18: cd: myrepo: No such file or directory
/full/path/to/script/myscript.sh: line 21: lualatex: command not found
[/CODE]
This answer on Serverfault suggested that I should put the path explicitly. I did that. It threw the same error again.
Note that I am accessing crontab via crontab -e or crontab -l, i.e. not as sudo.
Any idea how I can set this up?
cron tasks run as root so won't be using your private key. Try inserting su wrichik-basu into the script.
Alternatively I have done something similar with a GitHub action similar to the one described at https://blog.benoitblanchon.fr/github-action-run-ssh-commands/. This has the advantage that you can run it on every push (or whatever) instead of every hour regardless of changes, but has the disadvantage that you must expose an ssh login to your machine to the interweb. I run a cheap VPS that does this sort of thing.
Another alternative for this could be e.g. https://github.com/marketplace/actions/latex-compilation.
One thing to consider is how much disk you will be using each time crontab clones the repo.
Years ago, our company build czar had a fully automated build process that he was quite proud of. He left for vacation. It was a simple run this one script and you're done sort of thing.
I as project lead was given the task to run his script. All remaining code was checked in and our final project build was kicked off. It worked really well but during final product sniff tests we noticed a small problem with the code for one country, and decided we must fix this before shipping.
Everything went in the gutter, the build just failed. We didn't know why until he came back and said we ran out of disk space on the drive he backed up every copy of build output (maybe a years worth of builds) and forgot to tell or check beforehand or have a script contingency to delete old images when disk space was low.
Git repos can grow very large if you don't monitor their disk usage.
Little mistakes can cause an avalanche of problems -- Aesop the Programmer
Don't you mean try inserting su wrichik-basu into the crontab command?
https://serverfault.com/questions/352835/crontab-running-as-a-specific-user#352837 said:
Only /etc/crontab and the files in /etc/cron.d/ have a username field. In that file you can do this:
1 1 * * * username /path/to/your/script.sh
From root's crontab sudo crontab -e you can use:
1 1 * * * su username -c "/path/to/your/script.sh"
Or you can use the user's actual crontab like this:
sudo crontab -u username -e
Reply
Nope, that doesn't work. It throws the following error: Password: su: Authentication failure.
My repo is private, so I cannot use GH Actions.
(Abridged by me)
I don't think that's going to happen here anytime soon. If you look at my script, it is cloning only upto depth=1, i.e. only the last commit. I am also deleting all files that I have downloaded at the end (unless the script is killed midway, in which case the clean-up is done the next time the script is executed).
I did that too; I modified the job to:
Bash:
10 */1 * * * wrichik-basu /full/path/to/script/myscript.sh >/dev/null
This resulted in the following error, and the script never got executed:
Bash:
/bin/sh: 1: wrichik-basu: not found
By the way, if I execute the following command (which I can't paste here because XF throws an error):
I am getting the following output:
Bash:
Jun  7 13:10:01 PC_name CRON[781083]: (wrichik-basu) CMD (/full/path/to/script/myscript.sh >/dev/null)
All other jobs have (root) instead of (wrichik-basu). Does this somehow mean that the job is being run as my user rather than root?
Vanadium 50 said:
Doesn't this mean the problem is with git and its credentials, not any local permissions?
As I said, the script executes fine if I run it on a terminal. Without any intervention. If cron can run the script exactly like this, things should go fine. I can't make cron do that.
That doesn't preclude the problem being one of authentication. Is the environment the same? Is the directory this is being run in the same? And so on. I don't know what authentication git is using, but working interactively does not mean it will work non-interactively.
As a general rule,one's starting point should be that the error message is correct.
This is where the issue lies, I believe. I guess the environments are not the same, even though the user is the same. I put a simple whoami in crontab, and it told me that the user is me, not root. I put git config -l as a cron job, and it echo'ed the same config that I use, including the email and signing key, etc. What other things can I check to verify the environment?
I believe so. In my script, I am changing directories into the directory in which the script lies before doing anything else.
It's the SSH passphrase authentication issue because the environments are not exactly the same. After executing ssh -vT git@github.com as a cron job, this is what I got from the output:
Bash:
debug1: Offering public key: /path/to/key <key_name> <key_SHA>
debug1: Server accepts key: /path/to/key <key_name> <key_SHA>
debug1: read_passphrase: can't open /dev/tty: No such device or address
debug1: Trying private key: /path/to/key
debug1: No more authentication methods to try.
It seems that when I am working from terminal, it's not asking for the key because I have used it recently. That's not the case when working from cron. As per this comment on r/linuxquestions, cron works without a console, hence /dev/tty is null.
So, the option is to probably disable password authentication, as stated here: https://serverfault.com/a/1110635 I don't want to do that.
Is there a way I can pass the passphrase from the keyring?
Some answers never expire and some do in Computer Science. Your task should you decide to take it Mr Phelps is to determine which is which.
(...Mission Impossible theme.plays in the background while we all see a smoking tape recorder...)
PS: I've run into that scenario many times too.
Reply
