Using de Moivre's theorem on complex numbers cubed
  • Level: Undergrad
  • Thread starter Thread starter sarah786
    Theorem
12 replies · 5K views
sarah786
I have practiced solving de moivre's theorem... but i don't know why i keep getting the wrong answer in a particular question although i have checked a hundred times and havn't found a mistake...
this is the question i am talking about:
Simplify the following ( separate into real and imaginary parts ):
[-(1/2) + iota*(sq.root3)/2]
I have tried a hundred times using de moivre's theorem and i get "-1" each time... but when i do the same question using the formula (a+b)^3, i get "1" ... moreover, i have got a solution lest and there it says the answer should be "1" ... please if you can do the steps for me, i'll be very thankful and it'll be a big help... i will then be able to check where i am wrong... thank you...
Mathematics news on Phys.org
Isn't it already separated?
Real part = -1/2
Imaginary part = root(3)/2
no, i have to remove that power "3" somehow... i have to write a complex number to the power 1...
i have to "simplify" it and write the "simplified form" as a complex number...
From the looks of it, they want you to go the other direction and write it in a form like [tex]a e^{i \theta}[/tex], is that what the question is asking for?
no... i think i have very clearly stated my question...
Please write the expression in a different way. I don't see any power of three.
If (sq.root3) means [tex]\sqrt{3}[/tex] then it's already answered. If it means something else, then it's not obvious.
oopsss... sorryy... yeahh thanks for telling ... the question is:
[-(1/2) + iota*(sq.root3)/2]^3
de Moivre's theorum:
[cos(x) + i sin(x)]n = cos(nx) + i sin(nx)
n=3
cos(x) = -1/2
sin(x) = sqroot(3)/2
x=120deg
the RHS is
cos(3*120deg) + i sin(3*120deg) = 1
So 1 looks OK.
By the way, in the standard English, at any rate, the imaginary unit is "i" not "iota".
[itex]1/2+ i\sqrt{3}/2[/itex] in polar form is [itex]cos(\pi/3)+ i sin(\pi/3)[/itex].
Its third power is given by [itex]cos(3(\pi/3))+ i sin(3(\pi/3))= cos(\pi)+ i sin(\pi)= -1[/itex]
As Unrest says, perhaps you made the same mistake I did, and used [itex]1/2+ i\sqrt{3}{2}[/itex] instead of [itex]-1/2+ i\sqrt{3}/2[/itex]!
HallsofIvy said:
[itex]cos(\pi)+ i sin(\pi)= 1[/itex]
Now, as to why you are getting "-1"..
Maybe sarah did the same as you! ;)
Yes.. i did this same mistake :smile:
