Using Derivative to give a general formula
2 replies · 5K views
tmlrlz
a) Find dn/dxn (xn) for n = 1,2,3,4,5. Give the general formula
b) Give the general formula for dn+1/dxn+1 (xn)
a) n = 1 : d/dx (x) = 1
n = 2 :d2/dx2 (x2) = 2
n = 3 :d3/dx3 (x3) = 6
n = 4 :d4/dx4 (x4) = 24
n = 5 :d5/dx5 (x5) = 120
Notice that there is a recurring pattern:
1,2,6,24,120→ multiply the derivative of the previous term by the existing term (2 times 1 = 2, 3 times 2 = 6, 4 times 6 = 24, 5 times 24 = 120)
This is where I'm a little confused, i know what the pattern is and it is a bit hard to explain, however i wrote this out as the general formula:
dn/dxn (xn) = n[dn-1/dxn-1 (xn-1)
Would this be considered right? Or is the general formula suppose to be an arithmetic sequence or a geometric sequence?
b) dn+1/dxn+1 (xn+1)
n = 1 :d2/dx2 (x1) = 0
n = 2 :d3/dx3 (x2) = 0
n = 3 :d4/dx4 (x3) = 0
n = 4 :d5/dx5 (x4) = 0
n = 5 :d6/dx6 (x5) = 0
So then the general formula is:
dn+1/dxn+1 (xn+1) = 0
Once again is this correct or would there be another sequence equation for this like the last one. I am fairly sure that there is not much of an issue of a sequence formula for part b because it will always result in zero but for part a I am confused as to if my equation is correct and if it is not, what would the general formula be? Thank you.
The above looks fine. Another way to write the result is to use the factorial.
d2/dx2 (x2) = 2 = 2!
d3/dx3 (x3) = 6 = 3!
d4/dx4 (x4) = 24 = 4!
d5/dx5 (x5) = 120 = 5!
Your sequence 1, 2, 6, 24, 120, ... is neither an arithmetic sequence, in which each term is some constant plus the previous term, or a geometric sequence, in which each term is some constant times the previous term.
