Using divisibility patterns to eliminate composite Mersenne numbers
  • Level: Graduate
  • Thread starter arydberg
    Numbers Primes
6 replies · 4K views · last reply
arydberg
Following is a list of 39 Mersenne numbers. Some are prime and some are not. These are generated with x =( 2^n) -1. Many of the largest primes known are Mersenne primes.
I would like to point out that a sieve may be used to block out many non prime Mersenne numbers.
For example for n = 2 x = 3 but on closer inspection every even value of n other than n = 2 is non prime furthermore they are all divisible by 3, Thus we can cross out n=4, n=6, … up to n=38.
Also starting at n=3 and x = 7 we find that every third number larger than 3 is divisible by 7 so we could cross out n = 6, n=9, n=12 … up to n = 39.
Now let's move to n=5 or x = 31. now we can cross out every fifth number larger than n=5 as they are all divisible by 31
if we move to n=7 and x = 127 we find that every 7th number larger than 7 is divisible by 127 and can be crossed out.
11 should be crossed off as 2047 is not prime
My question is does this go on forever and can we use it to delete many Mersenne numbers as non primes.
The next prime is 11
n 2^n - 1
n = 1 x = 1
n = 2 x = 3
n = 3 x = 7
n = 4 x = 15
n = 5 x = 31
n = 6 x = 63
n = 7 x = 127
n = 8 x = 255
n = 9 x = 511
n = 10 x = 1023
n = 11 x = 2047
n = 12 x = 4095
n = 13 x = 8191
n = 14 x = 16383
n = 15 x = 32767
n = 16 x = 65535
n = 17 x = 131071
n = 18 x = 262143
n = 19 x = 524287
n = 20 x = 1048575
n = 21 x = 2097151
n = 22 x = 4194303
n = 23 x = 8388607
n = 24 x = 16777215
n = 25 x = 33554431
n = 26 x = 67108863
n = 27 x = 134217727
n = 28 x = 268435455
n = 29 x = 536870911
n = 30 x = 1073741823
n = 31 x = 2147483647
n = 32 x = 4294967295
n = 33 x = 8589934591
n = 34 x = 17179869183
n = 35 x = 34359738367
n = 36 x = 68719476735
n = 37 x = 137438953471
n = 38 x = 274877906943
n = 39 x = 549755813887
As a consequence of Theorem 18 from Hardy-Wright, we have the following
Corollary: For two natural numbers 1 < a and b: a[itex]{^b}[/itex] - 1 is composite if a > 2 (because (a - 1) divides a[itex]^{b}[/itex] - 1);
or in the case a = 2: if b = s * t (because 2[itex]^{s}[/itex] - 1 divides 2[itex]^{s*t}[/itex] - 1
yes but consider the number 11 which is a prime while 2^11 -1 is not a prime.
I think, my Corollary helps to delete all 2[itex]{^b}[/itex] - 1 with a composite b; but unfortunately, there is no help for sieving the Mersenne primes:
Theorem 18 by HW says (in short): 'If 2[itex]{^b} - 1[/itex] is a prime, then b is a prime'; and the 'other way round' is not valid
To show that (X^(2*n) ) - 1 has a factor of x-1 for any n. Consider x^2 - 1 = (x-1) * (x+1 )
so if x^2 -1 is a factor of a function then x-1 is a factor.
Consider x^4 - 1 = ( x^2 -1 ) * ( x^2 + 1 )
so x-1 is a factor of x^4 -1
consider x^6 - 1 = (x^2 -1 ) * ( x^4 + x^2 + 1 )
so x-1 is a factor of x^6 -1
consider x^8-1 = ( x^2 -1 ) * ( x^6 + x^ 4 + x^ 2 + 1 )
so x-1 is a factor of x^8 -1
etc
So it seems to me…
x^(2*n) - 1 = (x^2 -1 ) * ( x^(2*(n-1)) + x^(2 * (n-2)) + ……. + 1 )
