Using fourier series to sum 1/n^4
The discussion focuses on using Fourier series to sum the series 1/n^4. The initial approach involves expressing x^4 and manipulating it to derive a relationship with the series, leading to the conclusion that the sum equals π^4/90. A suggestion is made to use the polynomial x^4 - 2π^2x^2 to facilitate the summation process. Additionally, an alternative method is proposed, which involves calculating the Fourier series of x^2 and integrating it multiple times to find the desired sum. The conversation emphasizes the importance of selecting the right function through trial and error to achieve the desired series result.
Gregg
\sum _{n=1}^{\infty } \frac{1}{n^4}
I can do 1/n^2 easily by using x^2 as a function but for this I try
x^4=\frac{1}{2\pi }\int_{-\pi }^{\pi } x^4 \, dx+\sum _{n=1}^{\infty } \left(\frac{2}{\pi }\int _0^{\pi }x^4\text{Cos}[n x]dx\right)\text{Cos}[n x]
I arrive at:
\pi ^4=\frac{\pi ^4}{5}+\sum _{n=1}^{\infty } \frac{8 \left(-6+n^2 \pi ^2\right)}{n^4 }
\frac{4\pi ^4}{5}=\sum _{n=1}^{\infty } \frac{8 \left(-6+n^2 \pi ^2\right)}{n^4 }
f(x) = x^4 does not seem helpful to sum 1/n^4, maybe I need a polynomial in x of degree 4?
using x^4 - 2\pi^2x^2
x^4 - 2\pi^2x^2 = \frac{1}{2\pi }\int_{-\pi }^{\pi } \left(x^4-2\pi ^2 x^2\right) \, dx+\sum _{n=1}^{\infty } \left(\int _0^{\pi }\left(x^4-2\pi ^2 x{}^{\wedge}2\right)\text{Cos}[n x]dx\right)\text{Cos}[n x]
I end up with
-x^4 = -\frac{7 \pi ^4}{15} -\sum _{n=1}^{\infty} \frac{48 }{n^4 }
\frac{8 \pi ^4}{720} = \sum _{n=1}^{\infty} \frac{1}{n^4} = \frac{\pi^4}{90}
You can use Fourier transform of x^2 to sum 1/n^4 too.
Hint: compute the L^2 norm of the function x^2 in two ways, directly and using the Fourier coefficients.
Sorry to drag up an old thread, but I'm working on the same problem and understand everything except where the x^4 - 2pi^2 * x^2 came from. Any help would be appreciated.
The second post of the thread contains a trick which you don't need. The first post of the thread already contains the solution.
Yes the second part isn't useful for Fourier but is if you need to sum an infinite series. The function which you use needs to give you the series you want to sum and it is found with trial and error sometimes.
one more solution is possible for the sum of 1/n^4
. first calculate the Fourier series of x^2...
then integrate it ...3 times..
on first and third time the coefficient of integration will be zero you can put
x = 0;
after that after third time integration you will be able to find
the integration coefficient of 2nd time integration ...
that will calculate to -7/180
now put value x= pi in the second time integration ...
you will get the desired result...
  • · Replies 16 ·
