Using operators and finding expectation value
The expectation value of the time derivative of a quantum operator is expressed as d⟨O⟩/dt = ⟨∂O/∂t⟩ + (i/ħ)⟨[H,O]⟩. The discussion focuses on deriving an expression for ⟨dLx/dt + dLy/dt⟩, using the Hamiltonian H = H0 + μ0BzLz/ħ. Participants calculated the necessary commutators [Lx, H] and [Ly, H], noting that H0 commutes with all angular momentum operators. The final derived expression is ⟨dLx/dt + dLy/dt⟩ = ⟨∂(Lx + Ly)/∂t⟩ + (i/ħ)⟨iμ0Bz(Ly - Lx)⟩. Further simplification of this expression was also considered.
A9876
The expectation value of the time derivative of an arbitrary quantum operator \hat{O} is given by the expression:
d\langle\hat{O}\rangle/dt\equiv\langled\hat{O}/dt\rangle=\langle∂\hat{O}/∂t\rangle+i/hbar\langle[\hat{H},\hat{O}]\rangle​
Obtain an expression for \langled\hat{L}x/dt+d\hat{L}y/dt\rangle where \hat{H}=\hat{H}00Bz\hat{L}z/hbar
[\hat{L}x,\hat{L}y]=i*hbar\hat{L}z
[\hat{L}y,\hat{L}z]=i*hbar\hat{L}x
[\hat{L}z,\hat{L}x]=i*hbar\hat{L}y
[A,B]=AB-BA
\langled\hat{L}x/dt+d\hat{L}y/dt\rangle=d\langle\hat{L}x+\hat{L}y\rangle
=\frac{1}{ih} d\langle[\hat{L}y,\hat{L}z]+[\hat{L}z,\hat{L}x]\rangle/dt
=\frac{1}{ih}\langle ∂[\hat{L}y,\hat{L}z]+[\hat{L}z,\hat{L}x]/∂t\rangle+\frac{i}{hbar}\langle[\hat{H},[\hat{L}y,\hat{L}z]+[\hat{L}z,\hat{L}x]]\rangle
I'm not sure how to continue on from this
Just calculate the commutators [L_x, H] and [L_y, H]? You know that H0 should commute with all L's (why?), and the commutator with the extra term is easy to calculate.
I calculated the commutators [L_x, H] and [L_y, H] but I don't see how this helps me answer the question. I also can't figured out why H0 should commute with all L's.
Also \hat{H}0=-hbar2/2mr2 \{\frac{∂}{∂r}(r2\frac{∂}{∂r})+\frac{1}{sinθ}\frac{∂}{∂θ}(sinθ\frac{∂}{∂θ})+\frac{1}{sin squared θ}\frac{∂ squared}{∂\phi squared}\}+V(r)
where the angular-dependent part of the Hamiltonian corresponds to the total angular momentum operator \hat{L}2
You were given that
$$\bigg\langle \frac{d\hat{O}}{dt} \bigg\rangle = \bigg\langle \frac{\partial \hat{O}}{\partial t} \bigg\rangle + \frac{i}{\hbar} \langle [\hat{H},\hat{O}] \rangle.$$ What do you get if you let ##\hat{O} = \hat{L}_x##?
Also
$$\hat{H}_0 = -\frac{\hbar^2}{2mr^2}\left[
\frac{\partial}{\partial r}\left(r^2 \frac{\partial}{\partial r}\right) +
\frac{1}{\sin\theta} \frac{\partial}{\partial \theta} \left( \sin \theta \frac{\partial}{\partial \theta}
\right) +
\frac{1}{\sin^2 \theta} \frac{\partial^2}{\partial\phi^2}\right]+V(r)$$ where the angular-dependent part of the Hamiltonian corresponds to the total angular momentum operator \hat{L}^2
You should be able to prove that ##\hat{L}_i## commutes with ##\hat{L}^2## using the property [AB,C]=A[B,C]+[A,C]B and the commutation relations you listed above.
vela said:
You were given that
But shouldn't I substitute \hat{O}=\hat{L}x+\hat{L}y instead?
Oh I understand now. Thanks
You asked why you want to calculate ##[\hat{H},\hat{L}_i]##. Do you see why?
Yh I do. My final answer is
\langled\hat{L}x/dt+d\hat{L}y/dt\rangle=\langle∂(\hat{L}x+\hat{L}y)/∂t\rangle+\frac{i}{hbar}\langleiμ0Bz(\hat{L}y - \hat{L}x)\rangle
Could I further simplify this?
  • · Replies 0 ·
  • · Replies 0 ·
