Using Parseval's theorem to prove ∑(1/n⁴) = π⁴/90
2 replies · 4K views · last reply
TFM
The Fourier series for f(x) = x2 over the interval (−1/2, 1/2) is:
[tex]f(x) = \frac{1}{12}-\frac{1}{\pi^2} (cos 2\pi x - \frac{1}{2^2}cos4\pi x + \frac{1}{3^2}cos6\pi x) ...[/tex]
Using Parseval's Theorem, show that
[tex]\sum _{n = 1}^\infty \frac{1}{n^4} = \frac{\pi^4}{90}[/tex]
Fourier's Series:
[tex]f(x) = \frac{1}{2}a_0 + \sum _{n = 1}^\infty a_n cos\frac{2\pi nx}{l} \sum _{n = 1}^\infty b_n sin \frac{2\pi nx}{l}[/tex]
[tex]a_0 = \frac{1}{l} \int^{\frac{l}{2}}_{\frac{-l}{2}}f(x) dx[/tex]
[tex]a_n = \frac{1}{l} \int^{\frac{l}{2}}_{\frac{-l}{2}}f(x) cos \frac{2\pi nx}{l} dx[/tex]
[tex]b_n = \frac{1}{l} \int^{\frac{l}{2}}_{\frac{-l}{2}}f(x) sin \frac{2\pi nx}{l} dx[/tex]
Parseval's Theorem:
[tex]\frac{1}{2\pi} \int^{\pi}_{-\pi}f(x)^2 dx = \frac{1}{4}a_0^2 + \frac{1}{2} \sum _{n = 1}^\infty a_n^2 + \frac{1}{2}\sum _{n = 1}^\infty b_n^2[/tex]
See I'm not quite sure where to go from here. It says that it is a Fourier series, but it doesn't seem to fit with the definition of Fourier Series I have quoted below?
Any assitance would be greatly appreciated,
TFM
You multiplied the cosine and sine portions of the Fourier series together, they're supposed to be added. At any rate
For your f(x), a0=1/6 and then you can distribute the [tex]\frac{-1}{\pi^2}[/tex] to calculate the other ai's
And then the sine component is just all zeroes (so all your bi's will be 0)
So firstly,
[tex]f(x) = \frac{1}{2}a_0 + \sum _{n = 1}^\infty a_n cos\frac{2\pi nx}{l} + \sum _{n = 1}^\infty b_n sin \frac{2\pi nx}{l}[/tex]
And
[tex]a_0 = \frac{1}{6}[/tex]
As there are no sins, this implies that b_n = 0 (since b_n is the sin component.)
Multiplying out the brackets:
[tex]f(x) = \frac{1}{12} - (\frac{1}{\pi^2}cos 2\pi x - \frac{1}{\pi^2}\frac{1}{2^2}cos4\pi x + \frac{1}{\pi^2}\frac{1}{3^2}cos6\pi x ...)[/tex]
[tex]f(x) = \frac{1}{12} - (\frac{1}{\pi^2}cos 2\pi x - \frac{1}{4\pi^2}cos4\pi x + \frac{1}{9\pi^2}cos6\pi x ...)[/tex]
So the a_n seems to be an increasing value:
[tex]a_n = frac{1}{\pi^2}, frac{1}{4\pi^2}, frac{1}{9\pi^2}...[/tex]
Does this seem okay so far?
TFM
