Using strong induction to prove F(n) < 2^n
  • Thread starter ryou00730
    Proof
11 replies · 6K views · last reply
ryou00730
The Fibonacci numbers are defined recusively by:
F(0) = 0, F(1) = 1, for n > 1, F(n) = F(n − 1) + F(n − 2).
Use strong induction to show that F(n) < 2^n for all n.
n/a
I use my base case as F(2) = F(1) + F(0) = 1 which is less than 2^n = 2^2 = 4. After that I am not sure where to go with strong induction...
The induction hypthesis gives us
[tex]F(n)=F(n-1)+F(n-2)\leq 2^{n-1}+2^{n-2}[/tex]
Can you now prove that this is smaller then [tex]2^n[/tex]?
well 2^n-1 + 2^n-2 is equal to 2^n (2^-1 + 2^-2) = 3/4(2^n) but I don't see the logic behind equating the problem to less than or equal to 2^n-1 + 2^n-2
Let k>2, for all integers i, with 2<=i<k, F(i)<2^i would be my induction hypothesis I think?
Yes, that is correct. So in particular, we have
[tex]F(n-1)\leq 2^{n-1}~\text{and}~F(n-2)\leq 2^{n-2}[/tex]
So
[tex]F(n-1)+F(n-2)\leq 2^{n-1}+2^{n-2}[/tex]
woops, I meant n>2, so just replace all my k's with n's and so if I know that F(i)<2^i, then F(i-1) + F(i-2) < 2^i-1 + 2^i-2 which is F(i) < 3/4 2^i, so therefore F(i) must also be less than 2^i if its less than 0.75 of it, so the statement is true for all F(n)
thank you :), so in general with strong induction, you prove a base, then your induction hypothesis is that it works for all numbers between your base up until some value n, and you have to prove using this, that it also works for the n? thank you for all your help!
