knobelc
- 14
Why are my formulas not displayed correctly?
The discussion centers on the vacuum state of the Klein-Gordon field, specifically addressing the independence of the real and imaginary parts of the field in the ground state. The Lagrangian for the Klein-Gordon field is defined as ℒ = 1/2 ˙Φ² - (∇Φ)² - m²Φ², leading to the Klein-Gordon equation (□ + m²)Φ = 0. The canonical quantization introduces operators â(𝑘) and â†(𝑘), which are interpreted as annihilation and creation operators. The main questions posed involve proving that both parts of Φ(𝑘,𝑡) are independent Gaussian distributed and demonstrating the translational and rotational invariance of the vacuum state |0⟩.
PREREQUISITESPhysicists, particularly those specializing in quantum field theory, graduate students studying particle physics, and researchers interested in the mathematical foundations of quantum mechanics.
I'm not sure how to help you here, and nobody else seems to really do so either. First I noted thatknobelc said:So let me repete my question: How can I show in case of the Klein-Gordon field, that both, real part and imaginary part of \Phi(\vec{k},t) are independent Gaussian distributed? I don't expect it to be very difficult, but I don't see yet the formal calculation.
refers to a real KG (neutral), and this is also the case in your notes. Complex KG (charged) would have hadknobelc said:\pi(x) = \frac{\partial \mathcal{L}}{\partial \dot{\Phi}} = \dot{\Phi}.
(or whatever you use to note hermitian conjugate, but the operator will not be equal to \dot{\Phi} unless you have a real field)\pi(x) = \frac{\partial \mathcal{L}}{\partial \dot{\Phi}} = \dot{\Phi^{\dagger}}
There is no "\vec{k} in the ground state", is there ? Your HO-like construction creates plane waves with \vec{k} on the vacuum \left|0\right\rangle.knobelc said:From what I have written here, how can I prove that for a given \vec{k} in the ground state \left|0\right\rangle both the real and imaginary part of \Phi(\vec{k},t) = \int \Phi(\vec{x},t) e^{-i\vec{k}\vec{x}} dx^3 are independent Gaussian distributed with zero mean, i.e. by means of repeted measurements I would find the values of the real and imaginary part to be independent Gaussian random variables?
