Varation of Parameters fun diff EQ question, where do i go next?
8 replies · 4K views
mr_coffee
Varation of Parameters fun! diff EQ question, where do i go next?
This is my first attempt at doing Variation of parameters, didn't go to bad, things cancled out pretty well but now I'm almost done but I'm stuck!
The problem says: Find the solution of y''+15y'+56y = 54*e^(-5t), with y(0) = 8, and y'(0) = 2, y = ?
Here is my work:
http://img157.imageshack.us/img157/6798/s2ly.jpg
http://img157.imageshack.us/img157/6389/s26za.jpg
If you don't follow me or see an error right off the bat, please let me know! Thanks! :smile:
Now integrate u1= -54e3t and u2'= 54e2t to find u1 and u2 of course! Once you know those put them into "u1e-8t+ u2e-7t to get a "specific solution" and add that to the general solution of the homogenous equation.
ahh thanks Ivey, I'm alittle confused on what u mean when u said add it to the homogenous equation, the orginal equation wasn't homogenous was set equal to 54e^(-5t), are you saying add it to the r^2+15r+56 = 0? Thanks here is what i got now:
http://img140.imageshack.us/img140/848/lastscan1ia.jpg
Well, that's pretty much the whole idea! If [itex]y(t)= C_1e^{-8t}+ C_2e^{-7t}[/itex] is the general solution to y"+ 15y'+ 56y= 0 and [itex]y(t)= 9e^{-5t}[/itex] satisfies y"+ 15y'+ 56y= 54e-5t, then
The general solution to y"+ 15y'+56y= 54e-5t is
[itex]y(t)= C_1e^{-8t}+ C_2e^{-7t}+ 9e^{-5t}[/itex].
Thanks again Ivey!
I don't know if its right because webhw is still down, yay!
but this is what I got:
http://img114.imageshack.us/img114/6418/lastscan3jq.jpg
I personally think it's easier to solve it like this: First, as usual, you solve the homogeneous equation which is basically setting the right hand side (RHS) to zero, i.e. [itex]y"+ 15y'+56y=0[/itex]. This will give you [itex]y_{h}(t)=C_1e^{-8t}+ C_2e^{-7t}[/itex]. Next you solve the "special" or "particular" equation by making an ansatz (educated guess) depending on what expression you have on the RHS. In this case I would choose the ansatz [itex]y_{p}(t)=Ae^{-5t}[/itex]. Differentiate this and insert into the original equation gives you a value on A. The total solution is simply [itex]y=y_{h}+y_{p}[/itex]. And then use your initial conditions to get the values of [itex]C_1[/itex] and [itex]C_2[/itex].
Sound complicated, but that's how I used to solve these things. :smile:
And yes, I too got [itex]C_1=-40[/itex] and [itex]C_2=39[/itex].
i like ur method a lot better! But how did you make an educational guess of [itex]y_{p}(t)=Ae^{-5t}[/itex] ? I understand why u would guess an e^(t) but how did u konw it should be e^(-5t)? Thanks!
You can find out more about that method if you look up 'method of undetermined coefficients.' I find that reduction of order is generally faster because you don't need to memorise specific forms for certain situations.
I made the ansatz [itex]y_{p}(t)=Ae^{-5t}[/itex] because the the RHS of the original equation had the exponential term [itex]e^{-5t}[/itex]. More generally, I could have chosen the ansatz [itex]y_{p}(t)=Ae^{-5t}+Be^{+5t}[/itex] but the second term is redundant.
