Variable coefficient 2nd order DE
5 replies · 2K views · last reply
chipotleaway
This an example from Boyce+DiPrima's text on ODEs. Original problem is to solve 2t2y''+3ty'-y=0, given that y1=1/t is a solution.
But I'm stuck at the part where I'm to solve
[itex]2tv''-v'=0[/itex],
v being the second unknown solution.
In the text, they let w=v' which reduces the equation to
[itex]2tw'-w=0[/itex]
and solve by separation of variables.
I 'm trying to solve it by factoring differential operators (not sure what the method is called), so
[itex]v''-\frac{1}{2t}v'=0[/itex]
[itex]D(D-\frac{1}{2t})v=0[/itex]
Then I let [itex]w=(D-\frac{1}{2t})v[/itex],
[itex]\therefore Dw=0[/itex]
[itex]\therefore w=c_1[/itex]
[itex]\therefore v'-\frac{1}{2t}v=c_1[/itex]
But this isn't right - what am I doing wrong?
This looks like the method of annihilators. I'm not sure, but I don't think it will work if you don't have constant coefficients in your DE.
It looks like you skipped some steps.
If (D - 1/(2t)) v = 0, then dv/dt - 1/(2t)v = 0, or dv/dt = v/(2t). This is separable, and gives you a solution for (D - 1/(2t)) v = 0, but it doesn't also work for the original DE, y''+3ty'-y=0, at the start of your post.
You didn't show how you got from y''+3ty'-y=0 to 2tv''-v'=0, so I'm wondering if you made a mistake in that work.
The original equation is 2t2y''+3ty'-y=0
Let v be the unknown solution and y=vt-1. Differentiate y and y' and substitute it into the DE, work through the algebra and out pops 2tv''-v'=0.
Here're all the steps I took
[itex]v''-\frac{v'}{2t}=0[/itex]
Let [itex]w=(D-\frac{1}{2t})v[/itex], therefore the 3rd line becomes
[itex]Dw=0[/itex]
Since [itex]w=(D-\frac{1}{2t})v[/itex], then
[itex]v'-\frac{1}{2t}v=c_1[/itex]
Which I solved using integrating factors ([itex]\mu(t)=\frac{1}{\sqrt(t)}[/itex])
[itex]v=2c_1t+c_2\sqrt{t}[/itex]
Unfortunately the solution I got doesn't satisfy the original DE
Here's how they did it in the text:
[itex]2tv''-v'=-[/itex]
Letting w=v'
Separating variables and solving for w(t)
[itex]\therefore w(t)=v'(t)=ct^{\frac{1}{2}}[/itex]
[itex]\therefore v(t)=\frac{2}{3}ct^{\frac{3}{2}}+k[/itex]
So the annihilator method misses out on an integration...looks like it's the change of variables makes the difference. hmmm
Yeah, I don't know if annihilators are applicable when you have nonconstant coefficients. What you started out with is called variation of parameters or, in some books, variation of constants.
I followed that through and came up with the solutions.
Given that y = t-1 is a solution, you're looking for a solution of the form y = vt-1. Differentiating that twice and substituting into the original equation gets you to this equation:
-v' + 2v''t = 0, or equivalently, 2tv'' - v' = 0 (a lot of terms drop out)
Let u = v', so u' = v''
The last equation a couple of lines up becomes 2tu' - u = 0, or
du/dt = u/(2t)
Separating, we get du/u = (1/2) dt/t ==> ln u = (1/2) ln t = ln (t1/2)
So u = eln(t1/2) = t1/2
Backing out, since u = v', then we integrate u to get v: v = (2/3)t3/2
I'm being very cavalier about the constants of integration. In the end, we'll work it back in.
One more step. We have y = (1/t)v, so y = (1/t)(2/3)t3/2 = (2/3)t1/2.
The 2/3 factor can be discarded. All I needed was to find another linearly independent function to go with y1 = 1/t. The other is y2 = t1/2.
The general solution to the original DE is y = C1t-1 + C2t1/2
. As you see, the constants I ignored earlier are back in.
An alternate approach is to assume that solutions are of the form y = tr. Then y' = rtr -1 and r'' = r(r - 1)tr - 2
Substitute y, y', y'' into the original DE to get 2t2r(r - 1)tr -2 + 3trtr - 1 - tr = 0
Multiplying things out and collecting terms by powers of r, get get
(2r2 - r - 1)tr = 0
The quadratic can be factored to give r = -1 and r = 1/2, which is in agreement with the previous work.
The type of DE in this problem where you have decreasing powers of the independent variable as the orders of the derivatives decrease, has a name. I think this might be called an Euler equation or maybe an Airy equation. Without checking, I don't know for sure.
