Variable mass rocket equation with constant exhaust rate
2 replies · 3K views · last reply
vparam
A fully fueled rocket has a mass of 21,000 kg, of which 15,000 kg is fuel. The burned fuel is spewed out the rear at a rate of 190 kg/s with a speed of 2800 m/s relative to the rocket. If the rocket is fired vertically upward calculate its final velocity at burnout (all fuel used up). Ignore air resistance and assume g is a constant 9.80 m/s^2.
M * dv/dt = ∑F_ext + v_rel * dM/dt
I chose to set the upwards direction to be positive and dM/dt = R = 190 kg/s, so I can solve the problem in variable form and plug in. With the only external force being gravity, this gives
M(t) * dv/dt = -M(t) * g + v_rel * R
where M(t) is the remaining mass of the rocket. Rearranging this equation gives:
dv/dt = -((v_rel * R)/M(t)) - g
Since R is constant, M(t) = M_0 - R * t, where M_0 is the initial mass of the rocket. Plugging in gives:
dv/dt = -((v_rel * R)/(M_0 - R * t)) - g.
Solving as a separable differential equation, I arrived at the answer (assuming v = 0 at t = 0):
v(t) = -g * t + v_rel * ln(M_0 - R * t).
However, after plugging in values, I'm not able to get the correct answer. The solution instead has a different equation for v(t):
v(t) = -g * t + v_rel * ln(M/M_0).
Any help about where I could be going wrong with the physical setup or the math of this problem would be much appreciated. Thanks in advance!
Note that your result for v(t) does not satisfy the initial condition v = 0 at t = 0.
When you integrated ## \dfrac {dt}{M_0 - Rt}## from ##t = 0## to ##t = t##, did you forget to evaluate at the lower limit ##t = 0##?
Yes, it looks like that's where I went wrong. Thank you for your help!
