Variational expression: a demonstration
The discussion revolves around a variational expression involving a quantity K defined by integrals of functions E(x), e_n(x), and e_1(x). The main challenge is to demonstrate that a small perturbation in E(x) leads to a corresponding change in K that is proportional to the square of the perturbation. Participants debate the validity of this assertion, with one contributor providing a counterexample that shows a non-zero first-order term in the Taylor expansion of K, contradicting the original claim. The conversation highlights the complexities of perturbation theory and the conditions under which certain approximations hold true. Ultimately, the discussion emphasizes the importance of careful mathematical treatment in variational problems.
EmilyRuck
Hello!
My problem is with a variational expression. I have a quantity, say L, which could be determined by the ratio:
K = \displaystyle \frac{\left[\int_a^b E(x)e_n(x)dx\right]^2}{\left[\int_a^b E(x)e_1(x)dx\right]^2}
Where e_1(x), e_n(x) are known functions and n is an integer, with n > 1.
If I couldn't know exactly E(x) and I substitute it with E_0(x) + \delta E(x), I have to demonstrate that the corresponding \delta K is proportional to [\delta E(x)]^2.
So an error of 10 % made during the estimation of E(x) is an error of only 1 % for the corresponding estimation of K.
I tried to write the square of numerator and denominator:
K + \delta K = \displaystyle \frac{\left[\int_a^b [E(x) + \delta E(x)] e_n(x)dx\right]^2}{\left[\int_a^b [E(x) + \delta E(x)] e_1(x)dx\right]^2} =
\displaystyle = \frac{\left[\int_a^b E(x)e_n(x)dx\right]^2 + 2\int_a^b E(x)e_n(x)dx \int_a^b \delta E(x)e_n(x)dx + \left[\int_a^b \delta E(x)e_n(x)dx\right]^2}{\left[\int_a^b E(x)e_1(x)dx\right]^2 + 2\int_a^b E(x)e_1(x)dx \int_a^b \delta E(x)e_1(x)dx + \left[\int_a^b \delta E(x)e_1(x)dx\right]^2}
We can easily substitute the integral expression with letters and write:
K + \delta K = \displaystyle \frac{a^2 + 2ab + b^2}{c^2 + 2cd + d^2}
How could I do now?
Could I neglect the b^2 and d^2 terms because they are small? If I do this, then I could divide both numerator and denominator by c^2 and take the Taylor series expansion of the denominator truncated to the first order, so
K + \delta K \simeq \frac{\displaystyle \frac{a^2}{c^2} + \displaystyle \frac{2ab}{c^2}}{1 + \displaystyle \frac{2d}{c}} \simeq \left(\displaystyle \frac{a^2}{c^2} + \frac{2ab}{c^2}\right)\left(1 + \displaystyle \frac{2d}{c}\right)
But in this way I can't separate yet a and c from b and d, and I can't write a term with only c^2 or d^2. How can I proceed?
Thank you if you read this post,
Emily
EmilyRuck said:
Hello!
How could I do now?
Emily
The result you want is false, in general. Let us write \delta E(x) as r h(x), where h(x) is a function (not necessarily small) and r is the perturbation parameter (which we do think of a small). We have
K = K(r) = \left(\frac{a + br}{c + dr}\right)^2, where
\begin{array}{l}a = \int_a^b e_0(x) E_0(x) \, dx \\<br /> b = \int_a^b e_0(x) h(x) \, dx \\<br /> c = \int_a^b e_n(x) E_0(x) \, dx \\<br /> d = \int_a^b e_n(x) h(x) \, dx \end{array}<br />
Your result requires that the Taylor expansion of K(r) have the form K(0) + K_2 r^2, with no r^1 term. This is false: we have
K&#039;(0) = dK(r)/dr|_{r=0} = \frac{2a}{c^3}(bc - ad),
which is nonzero in general.
RGV
RGV
First of all, thank you for your reply!
Maybe you wanted to write:
\begin{array}{l}a = \int_a^b E_0(x) e_n(x) \, dx \\<br /> b = \int_a^b h(x) e_n(x) \, dx \\<br /> c = \int_a^b E_0(x) e_1(x) \, dx \\<br /> d = \int_a^b h(x) e_1(x) \, dx \end{array}<br />
Substituting:
bc - ad = 0 \Rightarrow \int_a^b h(x) e_n(x) \, dx \int_a^b E_0(x) e_1(x) \, dx - \int_a^b E_0(x) e_n(x) \, dx \int_a^b h(x) e_1(x) \, dx = 0
It seems to be true just if the product of the integrals equals the integrals of the products. Isn't it?
According to my notes, the result about [\delta E(x)]^2 should be true in general: my professor and another one said that in their lessons, without explaining why :frown:.
Emily
Substituting:
Emily
Sorry, no. The product b*c involves the integral of e_n * h, while the product a*d involves the integral of e_1 * h. There is no reason why they should cancel. Look at it this way:
bc-ad = \int_a^b h(x) e_n(x) \, dx \int_a^b E_0(w) e_1(w) \, dw - \int_a^b E_0(w) e_n(w) \, dw \int_a^b h(x) e_1(x) \, dx .
Does that look like 0 to you?
RGV
Substituting:
Emily
To convince you the result is false, let's look at a numerical example. (Of course, the functions you are using in your study may not resemble the ones I use below; it may be that for the special functions you are using, the result could, conceivably, hold---just not for the reasons you claim.) Let's take E_0(x) = x,\: h(x) = x^2,\: e_n(x) = \sin(\pi x/2), \: e_1(x) = \cos(\pi x/2), \: a = 0, \:b = 1. Then
\begin{array}{rcl}K &amp;=&amp; \frac{\left( \int_0^1 (x + r x^2) \sin(\pi x/2) \, dx \right)^2}{\left( \int_0^1 (x + r x^2) \cos(\pi x/2) \, dx \right)^2}\\<br /> &amp;\doteq&amp; \frac{4(2.283185308\: r + 3.141592654)^2}{(3.586419096+1.869604404\: r)^2} \\<br /> &amp;=&amp;3.069288133 + 1.261227604\: r - 0.527913928\: r^2 + O(r^3).<br /> \end{array}<br />
The term linear in r is not zero.
RGV
Sorry if I'm late (I didn't receive notifications by e-mail).
I tried to do some numerical examples too, with functions very similar to your ones. In the particular problem, it should be
e_n(x) = \sin(n \pi x/w)\\<br /> e_1(x) = \sin(\pi x/w)\\<br /> E(x) = \displaystyle \sqrt{(x - a)(b - x)}
with h(x) whatever error function and w a numerical positive constant; in my example I chose a sort of Gaussian distribution, h(x) = e^{-x^2}. E(x) should be the estimated function, so it is E(x) = E_0(x) + rh(x) and this is all we know about the function. Don't worry if somewhere E(x) becomes imaginary, it could happen.
But now I wonder why the professor said that . I agree with you, the first order error is nonzero!
Anyway, thank you so much for your calculations and observations, which are all right and useful!
Emily
With a more accurate example, I tried these realistic values for each integral:
a = 1.9;\\<br /> b=2.1;\\<br /> w = 4
and I had to consider E_0(x) = \sqrt{(x - a)(b - x)} instead of E(x) to make this example (I need an expression for E_0(x)!).
n = 3, 5 gave a difference bc - ad which is nonzero only if we consider a 10^{-7} precision (now a and b are the integrals, not their extremes!).
n = 9 gave a difference bc - ad which is nonzero only if we consider a 10^{-6} precision and so on for increasing values of n.
But the contribution of the nth term for increasing n is decreasing, so maybe we can consider in this case bc - ad \simeq 0.
I can't say which are the mathematical reasons for this result, but - strictly numerically - it seems to work.
Emily
Even if in this textbook the calculation are quite different, the results that I should demonstrate are the same: the statement is:
K «is stationary for small arbitrary variations in the electric field distribution about its correct value. It, therefore, follows that a first-order approximation to the electric field distribution will yield a second-order approximation to» the value of K.
(Robert E. Collin, Field Theory of Guided Waves, Ch. 8)
I don't know why you are arguing; we are talking about two different things. The thing you wrote down in your original post was not, in general, stationary, so that is why the first-order differential was nonzero. If you did have a stationary thing then, of course, the first-order differential would be zero BY DEFINITION, and that would mean your deviations would be of second or higher order---no argument there.
RGV
Oh, so it had been a misunderstanding. My professor presented the first expression,
as a variational, stationary expression. This is why I wrote the post.
So, the K expression is not stationary?
How can I recognize a stationary expression and where I can see that it has zero first-order differential?
Emily
Emily
I don't know the background or the context, so I don't know what K is supposed to be, or where it came from. I just took your word for it that K was supposed to be stationary at E = E_0, and I disputed that. However, maybe what you wrote is not what was meant, etc. At this point I give up.
RGV
