Optimizing Cable Direction for Minimum Force in Vector Addition of Forces
The discussion focuses on determining the direction of a third cable to minimize its force while maintaining a resultant force from two known cables. The user has calculated the resultant force (FR) from the two cables, yielding a magnitude of approximately 1605.28. However, there is confusion regarding the term "minimum" in the context of the problem. The goal is to find the angle θ that minimizes the force F in the third cable while balancing the resultant force. Clarification on the method to achieve this minimum force is requested.
Suy
Three cables pull on the pipe such that they create a resultant force having magnitude FR. If two
of the cables are subjected to known forces, as shown in the figure, determine the direction θ of
the third cable so that the magnitude of force F in this cable is a minimum. All forces lie in the
x–y plane.What is the magnitude of F? Hint: First find the resultant of the two known forces.
I have the solution
but i don't understand "minimum" in this question?
"the third cable so that the magnitude of force F in this cable is a minimum. "
Suy said:
...determine the direction θ of the third cable so that the magnitude of force F in this cable is a minimum.
F_{R}=\left[1200sin45\textdegree+800cos30\textdegree\right]\hat{i}+\left[1200cos45\textdegree-800sin30\textdegree\right]\hat{j}
F_{R}=1541.35\hat{i}+448.53\hat{j}
\left|F_{R}\right|=1605.28
tan^{-1}\left (\frac{448.53}{1541.35}\right)=16.22\textdegree
Cheers!
wat is the solution...can u give me?
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 25 ·
11K
  • · Replies 18 ·
