Vector component perpendicular
Mdhiggenz
Suppose v = <-3,-2, 1> and w = <-1,1,1>. Then
projw(v) = < -2/3, 2/3, 2/3 > ,
and the component of v perpendicular to w is?
I understood how to get the projection, and tried using the component formula Compaonb= a*b/magnitude( A )
But did not get the correct answer which is w2 = < -7/3, -8/3, 1/3 >
Where did I go wrong?
Is that projection given? Because that doesn't jive with what I get.
If you find the part of v that is parallel to the direction of w, then the only other part of v that remains must be perpendicular to w, no?
That is the answer to the projection yes, I don't understand what you are trying to explain though?
Okay, right, that projection is good. That is indeed the projection of v onto w. You could call it v_\parallel.
The point I'm making is that, if a + b = c, then b = c - a, so if v_\parallel + v_\perp = v, then v_\perp = ?
Perfect I got the correct answer. So what your saying is by getting the projection of v onto w. It gives me a vector V which is parallel to W, and to get the component of that vector we subtract the original vector v by the parallel component " if we want the perpendicular component".
Where I am confused is that there is a formula in my book for getting the component, and its in the form Comp v onto w = v*w/norm of v
Why would using that be incorrect?
Thank you for your help btw
The component of v parallel to w is obtained by first calculating the unit vector in the direction of w (dividing w by its own magnitude), and then dotting v with that unit vector. The component perpendicular to w is obtained by subtracting the component parallel to w (times the unit vector in the direction of w) from v.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
