Solve Vector Geometry Problem - Find Line Intersecting & Perpendicular
  • Thread starter Thread starter mathrocks
    Geometry Vector
The discussion focuses on solving a vector geometry problem to find a line through the point (3,1,-2) that intersects and is perpendicular to the line defined by the parametric equations x=-1+t, y=-2+t, z=-1+t. Participants clarify that two lines in R^3 can be perpendicular without intersecting, emphasizing the importance of the dot product in determining perpendicularity. The final solution involves deriving the vector such that the dot product with the direction vector <1,1,1> equals zero, leading to the line equations x = -2t + 3, y = -t + 1, z = 3t - 2.
  • Understanding of vector geometry in R^3
  • Knowledge of parametric equations of lines
  • Familiarity with the dot product and its properties
  • Ability to solve linear equations
  • Study the properties of vector perpendicularity in three dimensions
  • Learn how to derive parametric equations from vector equations
  • Explore the concept of direction vectors and their significance in geometry
  • Investigate applications of the dot product in physics and engineering
Students and professionals in mathematics, physics, and engineering who are working with vector geometry, particularly those interested in understanding line intersections and perpendicularity in three-dimensional space.
mathrocks
I have a question about solving the following problem
"Find the line through (3,1,-2) that intersects and is perpendicular to the line x=-1+t, y=-2+t, z=-1+t."
My question is regarding the intersection part, I know how to find the equation of the line that is perpendicular to another line but not both perpendicular and intersecting.
thanks
I'd think your forgeting that the dot product of two perpendicular vectors is 0 think about it...
what?
dot product...
the answer is as easy as you can think
(3,1,-2)+t(1,1,1)
why the hell you need dot product?
If two lines are perpendicular to each other, don't you think they're already intersecting?
what?
dot product...
(3,1,-2)+t(1,1,1)
And that line is perpendicular to x=-1+t, y=-2+t, z=-1+t?
No, two perpendicular lines in R^3 don't necessarily intersect.
Wouldn't (3,1,-2)+t(1,1,1) be correct for the line perpendicular to x=-1+t, y=-2+t, z=-1+t since the vector <1,1,1> is coming from that?
A direction vector of (3,1,-2)+t(1,1,1) is (1,1,1), and a direction vector of x=-1+t, y=-2+t, z=-1+t is (1,1,1). Two lines are perpendicular if and only if their direction vectors are perpendicular. Surely (1,1,1) is not perpendicular to (1,1,1)?
So, how would you go about finding a line that is perpendicular?
Ah.. I over-looked that.
The dot product between their direction vectors should be 0.
Note: there exist an infinite number of lines (in 3D) through a given point and perpendicular to a given line. Perhaps part of the problem is that there are too many answer. You should know that, in 2D, a perpendicular to <a, b> is <b, -a> since that way <a, b>.<b,-a>= ab-ab= 0. In 3d, the simplest thing to do is just take one of the components 0 so that the problem goes back to 2D.
To find a perpendicular to <1, 1, 1> try <0, a, b> What must a, b be?
Of course, <a, 0, b> and <a, b, 0> would work as well.
the line has the vector <1,1,1> as its direction
dot with the vector that lies on the perp line c...
<br /> \vect{c} = &lt;c_x, c_y, c_z&gt;
&lt;1,1,1&gt; dot &lt;c_x, c_y,c_z&gt; = 0
gives you
<br /> c_x = -c_y - c_z
c_y free
c_z free<br />
subracting the vector that points to the point on the line of perpendicularity (r), and the vector the point we are trying to make a line through gives us the vector in the direction of the line which is c...
<br /> &lt;r_x, r_y, r_z&gt; - &lt;3,1,-2&gt; = &lt;-c_y-c_z, c_y, c_z&gt;<br />
r_x - 3 = -c_y - c_z
r_y - 1 = c_y
r_z + 2 = c_z
however the terminal point of vector r must lie on the origal line..there fore..
r_x = t -1
r_y = t - 2
r_z = t - 1 ...substute...
<br /> (t-1) - 3 = -c_y - c_z
(t-2)-1 = c_y
(t - 1) + 2 = c_z
which we can easily solve for t...t = 2 put find the vector c by substuting in the t value...you'll get...
\vect{c} = &lt;-2, -1, 3&gt;
now we can form the line equation
x = -2t +3
y = -t + 1
z = 3t -2
done...check the dot product its perp
  • · Replies 42 ·
