Vector Integration: Solving \int_{S}\int n dS = 0 on Closed Surfaces
The integral \(\int_{S}\int n \, dS = 0\) for any closed surface \(S\) holds true under specific conditions related to vector fields. The discussion emphasizes that this result is valid when the vector field \(n\) is either tangential to the surface or zero everywhere. The divergence theorem is highlighted as a crucial tool for proving this relationship, particularly in demonstrating that the outward unit normal vector \(\mathbf{n}\) contributes to the integral's evaluation.
  • Understanding of vector integrals and their properties
  • Familiarity with the divergence theorem
  • Knowledge of unit normal vectors in vector calculus
  • Basic concepts of conservative vector fields
  • Study the divergence theorem and its applications in vector calculus
  • Explore the properties of conservative vector fields and their implications
  • Learn about the relationship between normal vectors and surface integrals
  • Investigate examples of vector fields that satisfy the condition \(\int_{S}\int n \, dS = 0\)
This discussion is beneficial for students and professionals in mathematics, physics, and engineering, particularly those studying vector calculus and surface integrals.
yusukered07
\int_{S}\int n dS = 0 for any closed surface S.
I can't solve this because I don't have any idea in Vector intregrals.
It should only equal zero if it is conservative since the partial of n with respect to x equals the partial m with respect to y. I am not sure if this what you are looking for since I am not sure what your question is.
Hint: The result is a vector, so look at its components. The x component of a vector V is V \cdot i. So look at, for example:
i \cdot \int\int_S \hat n\ dS = \int\int_S i\cdot \hat n\ dS
What is i there?
n is normal line, I think
i is the unit vector in the x direction, the usual i,j,k notation. n is the unit outward normal.
If the vector field is always tangential to the surface (and therefore perpendicular with the normal of the surface), this relation is trivially true. If the vector field is 0 everywhere, then this relation is also trivially true. What is the question exactly? Find all such vector fields n for which this relation holds?
So, will you help me to make a proof?
is there any proof you can show??
that's the question..
As LCKurtz already pointed out, \textbf{n} is the outward unit normal to whichever closed surface is integrated over. The problem is to show that this integral is zero for any closed surface.
We don't make proofs for you here. LCKurtz has given you a very good hint in his first reply, try using it and show us what you get. You should find that the divergence theorem is very useful to you here:wink:
  • · Replies 26 ·
