Boltzman Oscillation
- 233
- 26
You meant to say that ##\sin\theta\approx \theta## for small angles.anorlunda said:Sin Φ ≈ ∅ for small angles.
wait wait what? How is this true? I've never known this!anorlunda said:Sin Φ ≈ ∅ for small angles.
Ah I guess I could see that being true since the taylor expansion of sin is theta - theta^3/3! +theta^5/5! so a small theta would cause the terms after the first to be significantly small.Delta2 said:You meant to say that ##\sin\theta\approx \theta## for small angles.
You also see that from the fact that sin(0) = 0, sin'(0) = 1 and sin''(0) = 0. So sin is equivalent to the identity function up to the 2nd derivative around 0.Boltzmann Oscillation said:Ah I guess I could see that being true since the taylor expansion of sin is theta - theta^3/3! +theta^5/5! so a small theta would cause the terms after the first to be significantly small.
Are you looking for more than just basic Trigonometry here?Boltzmann Oscillation said:how can i determine that Θ = Δp/p ?
Well the other gentlemen helped me understand better now but maybe you can provide more insight. So, yes.sophiecentaur said:Are you looking for more than just basic Trigonometry here?
RPinPA said:It's instructive to take ##\sin(\theta)## for some small values of ##\theta## (always in radians) to see just how good the approximation is. Even at ##\theta = 0.1##, which is a little larger than what we usually consider "small compared to 1", it's a pretty good approximation.
