- #1
You meant to say that ##\sin\theta\approx \theta## for small angles.anorlunda said:Sin Φ ≈ ∅ for small angles.
wait wait what? How is this true? I've never known this!anorlunda said:Sin Φ ≈ ∅ for small angles.
Ah I guess I could see that being true since the taylor expansion of sin is theta - theta^3/3! +theta^5/5! so a small theta would cause the terms after the first to be significantly small.Delta2 said:You meant to say that ##\sin\theta\approx \theta## for small angles.
You also see that from the fact that sin(0) = 0, sin'(0) = 1 and sin''(0) = 0. So sin is equivalent to the identity function up to the 2nd derivative around 0.Boltzman Oscillation said:Ah I guess I could see that being true since the taylor expansion of sin is theta - theta^3/3! +theta^5/5! so a small theta would cause the terms after the first to be significantly small.
Are you looking for more than just basic Trigonometry here?Boltzman Oscillation said:how can i determine that Θ = Δp/p ?
Well the other gentlemen helped me understand better now but maybe you can provide more insight. So, yes.sophiecentaur said:Are you looking for more than just basic Trigonometry here?
RPinPA said:It's instructive to take ##\sin(\theta)## for some small values of ##\theta## (always in radians) to see just how good the approximation is. Even at ##\theta = 0.1##, which is a little larger than what we usually consider "small compared to 1", it's a pretty good approximation.
Vector math is a branch of mathematics that deals with the manipulation and analysis of vectors, which are mathematical quantities that have both magnitude and direction. It is used in various fields such as physics, engineering, and computer graphics.
The small angle approximation is a mathematical technique used to approximate the sine, cosine, and tangent functions for small angles. It is based on the fact that for small angles, the sine and tangent functions are approximately equal to the angle itself, and the cosine function is approximately equal to 1.
In vector math, the small angle approximation is used to simplify calculations involving small angles. It allows for easier manipulation of vector components and simplifies the equations used to solve problems involving vectors.
The small angle approximation is only accurate for small angles, typically less than 15 degrees. For larger angles, the approximation can lead to significant errors in calculations. Additionally, it is only applicable to certain types of problems and may not be useful in all situations.
Yes, the small angle approximation can be extended to other trigonometric functions such as secant, cosecant, and cotangent. However, the accuracy of the approximation decreases as the angle increases, so it is typically only used for small angles.
