Vector of differential solutions
10 replies · 2K views
boneill3
Hi Guy's
Let V be the set of functions [itex]f:R\rightarrowR[/itex]which solve the differential equation:
[itex]\frac{d^2y}{dx^2}=y[/itex]
Show that [itex]e_1:R\rightarrow R, x \rightarrow e^x[/itex] and [itex]e_2:R\rightarrow R, x\rightarrow cosh(x)[/itex]
Comprise a basis for V.
I have not done 2nd order differential equations and I was wondering if some one might give me a hint to a particular solution vector.
I know I need to prove that [itex]e^x[/itex] and [itex]cosh(x)[/itex] are linear independent to be a basis, but I need to show that any solution vector can be generated by them.
with the natural log we can't take the log of zero so when can the vector equal zero?
Well, first of all, your [itex]e_1[/itex] and [itex]e_2[/itex] won't comprise a basis for the space of all functions- that's infinite dimensional. What you mean is that V is the set of all functions that satisfy that differential equation.
That means you need to show the properties of a basis:
1) They are independent. In this case that means that the only way you can have [itex]Ae^x+ Bcosh(x)= 0[/itex], for all x, is if A= B= 0.
2) They span the space. That is, that if y is any function satifying the differential equation, then [itex]y= Ce^x+ Dcosh(x)[/itex] for some numbers C and D.
Thankyou for your explanation.
I don't know how I am going to prove this last statement. Do I need to have an explicit solution vector to show that it can be generated by [itex]y= Ce^x+ Dcosh(x)[/itex] ?
when you are dealing with these 2nd order differential equations does it mean that there are two solutions?
So if I prove that
[itex]y= Ce^x+ Dcosh(x)= 0[/itex] if and only if the constants C and D are zero than that basis can generate the solution set of vectors V.
As the functions inverses [itex]e^x[/itex] and [itex]cosh(x)[/itex]
are not defined for 0 ie ln(0) is undifined etc is that enough to say that they must be independent as they can only equal zero if both constants are zero?
No, whether they are indpendent or not has nothing to do with inverses.
Suppose Aex+ Bcosh(x)= 0 for all x. In particular, Ae0+ B cosh(0)= A+ B= 0. Further, if Aex+ Bcosh(x)= 0, a constant, for all x, then its derivative must be 0 for all x also: Aex+ Bsinh(x)= 0 for all x. Now take x= 0.
To show that these span the set of all solutions to this second order equation, suppose y is such a solution. Let A= y'(0) and B= y(0)- y'(0). Then, as before, z(x)= Aex+ B cosh(x) is a solution to the same differential equation (of course, you have shown that ex and cosh(x) satisfy the differential equation?) having z(0)= A+ B= y(0) and z'(0)= A= y'(0). Now use the "existence and uniqueness theorem".
Hi boneill3! :smile:
(try using the X2 tag just above the Reply box :wink:)
Hint: put z = dy/dx + y :wink:
Isn't the "existence and uniqueness theorem". mean that it is an solution in the space if the function and the first paritial derivative are continuous .
You say Hint: put z = dy/dx + y
we have
so
[itex]\frac{dy}{dx}=yx[/itex]
so
[itex]z = yx+y[/itex]
and
[itex]z' = y[/itex]
which are both continuous proving that Z is in the solution space
so
nooo … you can't integrate y and get yx :redface:
Differentiate z = dy/dx + y …
what do you get? :smile:
how do you differentiate dy/x ? what is its value?
He didn't say "dy/x" he said "dy/dx". And its derivative if the second derivative, [itex]d^2y/dx^2[/itex]. The derivative of z= dy/dx+ y is [itex]d^2y/dx^2+ dy/dx[/itex].
But I must admit, tiny tim, I don't see how that is related to this problem!
