MHB Proving Zp is a Vector Space for Prime p
Zp can be proven to be a vector space if and only if p is prime, as it must also be a field under addition and multiplication. The discussion emphasizes that the axioms of a vector space are satisfied when Zp is treated over a suitable field. There is some confusion regarding whether the task is to demonstrate Zp as a field instead of a vector space, but the consensus is that the focus remains on vector spaces. The exercise does not specify the field, but it is noted that any field can serve as a vector space over itself. Ultimately, the key takeaway is that Zp's status as a vector space hinges on p being prime.
THEcj39
How can I prove that
Zp is a vector space if and only if p is prime
What does the Z5 under addition and multiplication look like? What are the axioms of vector space?
A vector space over what field? Are you sure the problem is not to show that Zp is a field if and only if p prime?
The exercise doesn't specifies so I think is any field, and yes I'm sure the problem is vector spaces not fields
Any field is a vector space over itself so it is sufficient to show that Zp is a field if and only if p is prime.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 32 ·
  • · Replies 18 ·
  • · Replies 31 ·
