Vectors -- Adding velocity vectors to make a resultant
To determine the resultant vector A-C, given vector A at 44.0 units at 28 degrees north of east and vector C at 31.0 units at 90 degrees south of east, it's crucial to properly account for their orientations. The initial subtraction of vector lengths and angles is incorrect since they are not parallel. A recommended approach is to sketch the vectors to visualize their directions and apply vector addition by reversing the direction of vector C before adding. Additionally, clarifying the angle description for vector C may be necessary for accurate calculations. Understanding these principles will lead to the correct resultant vector values.
APphysicsOR
Determine the vectors A-C, given the vectors A and C in Fig. 3-32. Vector A=44.0 at 28 degrees north of east and vector C=31.0 at 90 degrees south of east.
I don't know any.
44.0-31.0=11.0, 28.0-90= -62
The answers are 64.6 and 53.1 degrees.
Hmmm... you took 2 vector lengths, and subtracted them. That works if they're parallel, but not at different angles.
Write your vectors in a couple different forms and post back. (I'm sure you've seen different ways to express the same vectors)
I don't know any.
We don't see Fig. 3-32, but I assume you do.
First step, sketch the vectors in their given orientation so you can see what you are dealing with.
Second step, remember the rule that says to subtract a vector you can reverse its direction and add it.
BTW, you might need to brush up on your arithmetic, too. :wink:
It's unusual and longwinded to describe a direction as 90 degrees South of East. Are you sure you have that specification correct?
  • · Replies 19 ·
