Vectors with velocity and acceleration
The problem involves an object moving with constant acceleration in a two-dimensional space, specifically with an acceleration directed east and an initial velocity directed north. The goal is to determine the magnitude of the velocity after a specified time.
  • Mixed
  • Participants discuss the need to find the components of velocity and acceleration, considering the use of kinematic equations. There is mention of integrating acceleration and the confusion surrounding calculus concepts like derivatives and integrals.
Some participants are exploring algebraic methods to find the final velocity, while others express uncertainty about the calculus concepts involved. There is a recognition that the problem can be approached using the components of motion, but no consensus on a complete method has been reached.
Participants note that the discussion is taking place in the context of a calculus-based physics class, but there are varying levels of familiarity with the necessary mathematical concepts.
ryan1180
An object moves with constant acceleration a = 1.9 m/s2 in the due East direction. At time t = 0, the velocity of the object is v0 = 2.2 m/s in the due North direction. What is the magnitude of the velocity at t = 2 s
a]v=2.9 m/2
b]v = 3.6 m/s
c]v = 4.1 m/s
d]v = 4.4 m/s
e]v = 6.0 m/s
I am really lost on this one, my manual for this class doesn't seem to tell me anything about this
Would I have to find the components of the velocity or acceleration and then use vf=Vo+at?
I tried calculating both the x and y values of the velocity but that didn't help me at all when i plugged them into the equation
Hello! I'd like to try and help. I hope it is right!
We have two directions, North and East. Thus East = x axis, North = y axis. I'm sure you had that, but just saying.
We know that the resultant a is in the east direction and is 1.9 m/s^2. Thus, the y component is zero. So a = ax.
We also know that Vi is 2.2 m/s due north, and thus Vix = 0 m/s, so Viy = Vi.
We can get the velocity resultant by integrating a = 1.9 m/s^2. What would the constant of equation represent? We can then plug in t = 2s and hopefully get the correct answer.
Thanks for your help, I got as far as the fourth line, however this class is take with Calc I, so the last line and the whole topic of integration makes no sense to me, or is it just that I'm unfamiliar with the terms you are using?
Ah. That is fine! You haven't covered integration in Calc 1 yet. Which is fine. I'm guessing this is still calc based physics and therefore it's ok to use calculus in your answers.
You have learned about derivatives a bit? Integrals are often referred to as an "anti-derivative". So a = a constant. What kind of derivative would give us that answer?
Perhaps there is a way to do it algebraically, I just looked at it this way first. . .
Haha! there is a way to do it algebraically. You already have the equation!
We have vi, a, and t. We can solve for Vf at t = 2 sec
So to obtain the final answer I would just use vf=vo+at?
vf=2.2+(1.9)(2)?
It seems so. . . we are looking for the magnitude of the velocity resultant, so we aren't concerned with the new direction.
I'm getting all paranoid because it seems simple lol. Good luck!
Thanks for your help. That's what I originally had but thought it was too simple as well!
vf=2.2+(1.9)(2)?
You are mixing components here. The acceleration in along the x-axis (east) and the vo=2.2 m/s is along the y-axis (north).
You need to apply the formula for each axis, find the two components of the velocity at time t and then find the magnitude.
  • · Replies 17 ·
