Velocity, acceleration, and position graphs
The discussion focuses on understanding how to derive acceleration-time and velocity-time graphs from a position-time graph of a basketball thrown upwards. The acceleration-time graph is a constant negative line due to gravity, which accelerates all objects at 9.8 m/s² downwards, regardless of mass. The velocity-time graph can be derived using the equation v=at, while the position can also be expressed in a similar equation. For an object with constant negative acceleration, the position vs. time graph will show a curve that reflects this motion. The conversation emphasizes the importance of using equations to understand the relationships between these graphs.
Porcelain
I have the answers, but I don't know how to get them.
The starting graph is a position-time graph of a basketball being thrown straight up into the air.
From that graph i have to find an acceleration-time graph, and a velocity-time graph.
Can someone explain to me the acceleration-time graph? why is it a constant negative line, if the graph of the position graph first goes up then down?
I think I understand how the velocity-time graph works with this.
My next question wants a graph of position vs. time, and a graph of velocity vs. time for an object moving with a constant negative acceleration.
again i have the answers, but I really don't know how to get to them.
thanks in advance for the explanations :)
The acceleration-time graph is a line, which means acceleration remains constant. That's how gravity works; all objects, regardless of mass, fall at an acceleration of 9.8 m/s^2 down.
For your second question, try writing out the object's velocity in an equation; ditto for its position. v=at, and d=?
A horizontal line with a slope of zero, right?
