Velocity and Acceleration Equational Problem ( making sense)
3 replies · 6K views · last reply
zippeh
A man is running at speed c (much less than the speed of light) to catch a bus already at a stop. At t=0, when he is a distance b from the door to the bus, the bus starts moving with the positive acceleration a. Use a coordinate system with x=0 at the door of the stopped bus.
Part A:
What is xman(t), the position of the man as a function of time?
Answer symbolically in terms of the variables b, c, and t.
v(t) = V0+at
I know that I need to use this equation:
v(t) = V0+at
But I am confused because the answer is: xman(t) = -b+ct. This doesn't make sense to me because in order to use this equation, c would need to be the acceleration, not the velocity. I tried reviewing the book and it really doesn't help. I know that the mans speed is constant, but with an acceleration c, wouldn't his velocity increase in time?
Sorry if this is a simple question, I just am trying to understand the foundations so that I can better apply myself later in the course. Thank you for your time.
Part A:
v(t) = V0+at
v(t) = V0+at
Welcome to PF!
If you are asked to find displacement , why should you be using equation for finding velocity .
You need to use the equation x(t) = x0 + ut+(1/2)at2 .
Here x0 = -b , u=c , a=0 .
Does that make sense ?
Oh wow... thanks!
I was looking through the equations that I know, and I couldn't arrive at the answer with anything that I had (so I thought). I immediately looked for an equation that looked similar to the answer, which was what I gave above. Thanks for making it clear, I didn't really ever think to set accel. to 0, which was what was made me stuck. I appreciate you helping me! :)
