Velocity and acceleration of an airplane
An airplane lands on a carrier deck at 150 miles per hour and comes to a stop using an arresting device over a distance of 500 feet. Participants discuss how to calculate the acceleration and time required to stop, noting that the problem provides initial velocity, final velocity, and distance as key variables. The conversation highlights the use of kinematic equations to derive the necessary calculations, with emphasis on understanding average velocity. Clarifications are made regarding the initial and final velocities, with the final velocity being zero when the airplane stops. The discussion concludes with encouragement to apply the kinematic formulas to solve the problem.
aldeemativo
VELOCITY AND ACCELERATION:
An airplane lands in a carrier deck at 150 miles per hour and is brought to a stop by an arresting device in 500 feet.
What is the acceleration?
What is the time required to stop?
Welcome to Physics Forums.
You seemed to have missed a section: :wink:
aldeemativo said:
hootenanny said:
welcome to physics forums.
what do you mean?
aldeemativo said:
what do you mean?
You haven't showed us your attempt at the solution.
BUT I've got no idea how..., i don't know because the given variables are only two which are: the distance, velocity but in physics formula for the computation of this problem requires three or more than variables given.. could you teach me?
You actually know three variables:
  1. Distance
  2. Initial Velocity
  3. Final Velocity
  1. Distance
  2. Initial Velocity
  3. Final Velocity
could you tell me what is the initial and final velocity... if i will be able to know that, then i think i could do it... thank you so much...
I'm sure that you could work that out for yourself. You are given the initial speed and you are told that the aircraft comes to rest. What is the aircraft's speed when it isn't moving?
zero?
aldeemativo said:
zero?
Exactly :smile:
Hootenanny said:
Exactly :smile:
oh... so half of 150 gives if velocity = (Final velocity + Initial velocity) / 2, then, it will give me a 75 average velocity right?
Why are you computing the average velocity?
THANx Hootenanny... :) i know this is just a simple problem yet i don't know how to solve it... thanks a lot... more powers!
You should be able to use kinematic (SUVAT) equations to solve this.
To find the time needed to come to a stop with: avg velocity = distance/time
yet there's no time indicated from the given problem making me think about the velocity to get the time... can you help me with this?? thanks a lot...
v0 = 150 mph = 67.1 m/s
v1 = 0 m/s
\Deltax = 500 ft = 152.4m
use v12 = v02 + 2a\Deltax
I think you can solve it from there?
You are on the right track. Use the average velocity to get the time required to stop.
There is also a kinematic formula that can give you the answer directly.
i'll try... thank u so much.. :)
