Velocity and Mass to Acceleration
Zales
I am graphing an equation, but my software will not graph more than two variables. I have velocity (v) and velocity dependent mass (m sub 0), but I need to write it in terms of x, which I have as acceleration. This problem stems from me plugging in the following equation for the relationship between speed and mass: (m sub 0)/sqrt(1-((v/c)^2). If it is even possible to do it another way, please let me know. Or if it's not possible and I need better software, please let me know is that is the case also.
Thank you,
Zales
PS. This post is very poorly worded. Here is a link to a much better formatted equation, and if you wish for me to clarify anything, please let me know.
http://www.physlink.com/Education/AskExperts/Images/ae388c.gif
You'll have a much more clear picture of what's happening if you choose your variable to be v, and set c=3x108 and m0 to be a parameter that you change to whatever you like. Better yet would be to choose your variable to be v/c which means to set c=1 and then v will be represented by a percentage of c. So at x=0.5 on the graph, that means that v will be half of the speed of light.
Sorry, maybe I should have added more information. What I'm trying to graph is F=Ma, with 'F' as y, 'M' as the slope, and 'a' as 'x'. In slope intercept form, I had F=Ma+0. The equation is equivalent to 'M', so the equation was plugged in for 'M'. I have 'c' as 2.998x10^8. My full equation, so far, is y=(m/(sqrt(1-(v/(2.998*10^8))^2)))x+0.
PS. How did you input your subscripts and superscripts?
You may want to head over to the physics section of the forum as well to get a better idea of what your equations should actually be, because relativistic mass increases in a stationary reference frame as v approaches c, so it's not quite as simple as that. In 1 dimension (to keep things simple for the moment) your equation would be
[tex]F=\gamma ^3m_0a[/tex]
where a is simply the change in velocity over time, [itex]a=\frac{dv}{dt}[/itex] and [itex]\gamma[/itex] is the lorentz factor [itex]\gamma=\frac{1}{\sqrt{1-v^2/c^2}}[/itex]
It gets more complicated in 3 dimensions though. You'll have situations where the particle won't accelerate in the direction you applied the force, which is very counter-intuitive with respect to Newtonian mechanics.
I'm sure you'll get more informed answers in the physics section though.
Anyway, back to your question. You can still graph it on a 2d plane, but you'll have v as a parameter that you can adjust accordingly. What I mean by this is if you think about graphing y=x and y=2x on the same plane to compare their differences, you can do the same except you'll choose v=0.1, v=0.5, v=0.9 etc. and compare those.
The superscripts are the x2 button that's above the message you're sending. Or you can learn all about LaTeX to get real fancy :wink:
