Velocity from spring pushing on 2 masses
  • Thread starter Thread starter JoeyBob
    Spring Velocity
JoeyBob
See attached
Ep=1/2kx^2, W=Ek
So i know Ek=123.48 from the potential energy that converts into kinetic energy (Ep=1/2kx^2).
Now by conservation of momentum, m1v1=m2v2
So m2Sqrt(2Ek/(m1+m2))=m1v1
This is where I am making a mistake I think, but not sure how.
Answer is suppose to be 4.44
So I tried something else
Ek=Ek1+Ek2
2Ek-m1/m2 * v1^2=v2^2
And substitute this into m1v1^2=m2v2^2, but this didn't give the right answer either.
Not sure how you arrive at some of the equations in post #1 and #2, but let's just reset:
Using conservation of energy (potential energy of spring=sum of kinetic energies) gives you one equation. I don't see this equation in post #1, I see some other equation which doesn't look right.
Using conservation of momentum you get the other equation ##m_1v_1=m_2v_2## which is correct from your post #1.
SO , you will have two equations with two unknowns the velocities of the two bodies ##v_1,v_2##.
I read that as ##v_1=\frac{m_2}{m_1}\sqrt{\frac{kx^2}{m_1+m_2}}##.
But that's not what I get. Please post your working.
