Velocity of Megastructures in Berlin Train Terminal
  • Thread starter Thread starter arisu4
    Velocity
The discussion centers on the tipping of towers at the Berlin Train Terminal, specifically their movement at a speed of 6 meters per hour. Participants clarify that this speed refers to the linear velocity of the top of the tower rather than angular velocity. The measurement is derived from the formula V = ωR, where V is linear velocity, ω is angular velocity, and R is the height of the tower. The use of meters per hour instead of meters per second is noted as a means to simplify understanding of the slow movement. Overall, the conversation focuses on the physics behind the tipping mechanism and how the speed is calculated.
arisu4
Hello,
I recently watched a National Geographic, Megastructures documentary and I have a question, I thought posting it here would be a good idea :)
(its named "Berlin Train Terminal", the part I want to ask about is when they tip over two towers)
this is the image (I took a screen capture from the episode)
http://imageshack.us/photo/my-images/715/megastructuresberlintra.jpg/they say that the towers are moving at 6 metres per hour. (the speed of tipping over)
how is that numbered determined and measured? is it a specific king of velocity? (like angular, but I don't think angular v is measured in m/s, or in this case m/hr
Thanks a lot for any replies
welcome to pf!
hello arisu4! welcome to pf! :smile:
arisu4 said:
… they say that the towers are moving at 6 metres per hour. (the speed of tipping over)
it's probably the speed of the top of the tower …
as you say, m/hr must be an actual speed (not an angular speed) :wink:
(and they're using hr instead of s because that's easier to understand at such slow speeds)
That is the velocity measured for arc made in pitch circle of the tower when it is moving, which can be calculated from angular velocity if we know the length of tower by using the formula:
V= ωR
where,
V= velocity
ω= Angular velocity
R= length of tower
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 17 ·
26K
