Verification of solution to Heat Equation
  • Thread starter Thread starter rexasaurus
    Heat Heat equation
7 replies · 3K views
rexasaurus
1. verify that u(t,x,y)=e-λtsin(αt)cos(βt) (for arbitrary α, β and with λ=α2+β2) satisfies the 2-D Heat Equation.
2. ut=Δu
3. I began with:
Δu=uxx+uyy.
note the equation does not contain variable "x"
so uxx=0 i.e. Δu=uyy
uy=e-λtsin(αt){-βsin(βt)}
uyy=e-λtsin(αt){-β2cos(βt)}
next I found ut
ut=cos(βy) {e-λtαcos(αt)+sin(αt)-λe-λt}
I have tried to reduce both equations but don't see how they are equal. I also have tried using the λ=α2+β2 to re-write the eq. Any suggestions?
rexasaurus said:
1. verify that (for arbitrary α, β and with λ=α2+β2) satisfies the 2-D Heat Equation.
2. ut=Δu
3. I began with:
Δu=uxx+uyy.
next I found ut
Your equation is transcribed incorrectly. Your original equation should be:
u(t,x,y)=e-λtsin(αx)cos(βy)
The original equation was posted incorrectly.
The actual question states:
u(t,x,y)=e-λtsin(αt)cos(βy)
My apologies
The heat equation in 2D is the Fourier equation. I think the answer they want you to check out is:
u(x,y,t) = e**(-lambda*t) * sin(alpha*x) * cos(beta*y)
Take the partial derivatives and plug them back into the original equation and you'll see that the equation is satisfied if lambda = alpha**2 + beta**2. The original equation is the Laplacian of u equals the partial of u with respect to time.
I checked the problem statement
The question actually states:
Could the instructor possibly have made a typo??
When I set ut=uyy (from simplifying Δu) I was able to substitute: λ=2+β2
My last line reads:
αcos(αt)+β2sin(αt)=(α2+β2)sin(αt)
Any thoughts?
Of course he could have. That t in the sine term should be x. Then it all works.
