Verify the Trigonometric Identity
15 replies · 3K views
FritoTaco
Problem 1
: [itex]csc(tan^{-1}\dfrac{x}{2})=\sqrt{\dfrac{x^{2}+4}{x}}[/itex]
Problem 2: [itex]\sqrt{\dfrac{1-sinx}{1+sinx}}=\dfrac{|cosx|}{1+sinx}[/itex]
Quotient Identities
[itex]tan\theta=\dfrac{sin\theta}{cos\theta}[/itex]
[itex]cos\theta=\dfrac{cos\theta}{sin\theta}[/itex]
Pythagorean Identites
[itex]sin^{2}\theta+cos^{2}=1[/itex]
[itex]cot^{2}\theta+1=csc^{2}\theta[/itex]
[itex]tan^{2}+1=sec^{2}\theta[/itex]
Recirpocal Identites
[itex]sin\theta=\dfrac{1}{csc\theta}[/itex]
[itex]cos\theta=\dfrac{1}{sec\theta}[/itex]
[itex]tan\theta=\dfrac{1}{cot\theta}[/itex]
[itex]csc\theta=\dfrac{1}{sin\theta}[/itex]
[itex]sec\theta=\dfrac{1}{cos\theta}[/itex]
[itex]cot\theta=\dfrac{1}{tan\theta}[/itex]
Cofunction Identities
(maybe useful?)
[itex]sin(\dfrac{\pi}{2}-\theta)=cos\theta[/itex]
[itex]cos(\dfrac{\pi}{2}-\theta)=sin\theta[/itex]
[itex]tan(\dfrac{\pi}{2}-\theta)=cot\theta[/itex]
[itex]csc(\dfrac{\pi}{2}-\theta)=sec\theta[/itex]
[itex]sec(\dfrac{\pi}{2}-\theta)=csc\theta[/itex]
[itex]cot(\dfrac{\pi}{2}-\theta)=tan\theta[/itex]
Note: [itex]\sqrt{x^{2}}=|x|[/itex]
Problem 1: Any ideas on how to get started? I have no idea what to do with inverse tangent and that stupid x/2 and it makes me mad! I know I need some work for it to be a valid thread so here goes nothing.
Maybe manipulate the left side?
[itex]csc(cot\theta)[/itex]
...yup, I'm totally lost.
Problem 2:
I manipulated the left side
[itex]\dfrac{\sqrt{1-sinx}}{\sqrt{1+sinx}}\cdot\dfrac{\sqrt{1-sinx}}{\sqrt{1-sinx}}[/itex]
[itex]\dfrac{1-sinx}{\sqrt{(1+sinx)(1-sinx)}}[/itex]
[itex]\dfrac{1-sinx}{\sqrt{(1+sin^{2}x)}} <--\sqrt{x^{2}}=|x|[/itex]
[itex]\dfrac{1-sinx}{|cosx|}[/itex]
[itex]\dfrac{|cosx|}{1+sinx}[/itex] Am I allowed to just switch it around like that?
[itex]\dfrac{|cosx|}{1+sinx}[/itex] = [itex]\dfrac{|cosx|}{1+sinx}[/itex]
on Phys.org
for 1 use
$$\csc x=\dfrac{\sec x}{\tan x}$$
and
$$\sec ^2 x=1+\tan^2 x$$
for 2 start with
$$\dfrac{|\cos x|}{1+\sin x}=\sqrt{\left(\dfrac{\cos x}{1+\sin x}\right)^2}$$
@Orodruin, if I draw a triangle, csc is [itex]csc\theta=\dfrac{r}{y}[/itex], how do I find r? Is it just [itex]r=(\sqrt{x^{2}+4})[/itex]? Which makes it less confusing actually. But still confused because now I have:
[itex](\sqrt{x^{2}+4})=\dfrac{\sqrt{x^{2}+4}}{x}[/itex]
@lurflurf, How does the numerator become [itex]cosx[/itex]? Doesn't it need to be squared to use the Pythagorean identity in order to change its value?
@SammyS, is that when I was finding the common denominator?
^It is squared I have used
$$|x|=\sqrt{x^2}$$
\left|\dfrac{\cos x}{1+\sin x}\right|=
\sqrt{\left(\dfrac{\cos x}{1+\sin x}\right)^2}=
\sqrt{\dfrac{\cos^2 x}{(1+\sin x)^2}}$$
FritoTaco said:
Problem 1
You can not verify (1) as it is wrong. ##csc(tan^{-1}\dfrac{x}{2})=\dfrac{\sqrt{x^{2}+4}}{x}##
is true.
@SammyS, Oh. I see, where. I had in the denominator with a (+) sign. Here is what it should look like: [itex]\dfrac{1-sinx}{\sqrt{(1-sin^{2}x)}}[/itex]
@lurflurf, Oh. I see now, is this right?
[itex]\sqrt{\left(\dfrac{cosx}{1+sinx} \right)^{2}}[/itex]
[itex]\sqrt{\dfrac{cos^{2}x}{(1+sinx)^{2}}}[/itex]
[itex]\sqrt{\dfrac{1-sin^{2}x}{1+sin^{2}x}}[/itex]
[itex]\sqrt{\dfrac{1-sinx}{1+sinx}}=\sqrt{\dfrac{1-sinx}{1+sinx}}[/itex]
Is this correct?
Also, for problem 2. I'm confused on how you get [itex]cscx=\dfrac{secx}{tanx}[/itex] Did you use an identity?
@ehild, Oh, that was an editing mistake, my bad. It's [itex]csc(tan^{-1}\dfrac{x}{2})=\dfrac{\sqrt{x^2+4}}{x}[/itex].
$$\csc x=\frac{1}{\sin x} \\
\csc x=\frac{1}{\sin x}\cdot\frac{\sec x}{1/\cos x} \\
\csc x=\frac{\sec x}{\sin x/\cos x} \\
\csc x=\frac{\sec x}{\tan x}$$
Oh okay, but how does that get me to a value of 4 which is part of what I need for my end result? I did the triangle like someone previously suggested which worked but I was missing an x in the denominator. Hmmm...
Use the relation ##\sin(\alpha)=\frac{tan(\alpha)}{\sqrt{1+tan^2(\alpha)}}## with ##\alpha=\tan^{-1}(x/2)##
I figured it out. It was actually easier than I thought...
If you plot the tangent of [itex]\dfrac{x}{2}[/itex] in Quadrant one of a triangle, you just find the hypotenuse using the Pythagorean theorem which is [itex]\sqrt{x^{2}+4}[/itex]. Then find the csc which is [itex]csc\theta=\dfrac{hyp}{opp}=\sqrt{\dfrac{x^{2}+4}{x}}[/itex]. Thanks guys!
It is wrong. x should be outside the square root.
@ehild, Ahhhhh. Thanks for pointing that out, I keep making that editing mistake. It should be this, [itex]csc\theta=\dfrac{hyp}{opp}=\dfrac{\sqrt{x^{2}+4}}{x}[/itex]
Note: The original problem should have the denominator of 'x' outside the square root. I didn't initially put that in the problem, to begin with.
