Verifying an Integral Representation of the Euler Constant
9 replies · 3K views
the_kid
I need to verify an integral representation of the Euler constant:
[itex]\int^{1}_{0}[/itex][itex]\frac{1-e^{-t}}{t}[/itex]dt-[itex]\int^{\infty}_{1}[/itex][[itex]\frac{e^{-t}}{t}[/itex]dt=[itex]\gamma[/itex]
OK, I'm supposed to use this fact (which I have already proved):
[itex]\sum^{N}_{n=1}[/itex][itex]\frac{1}{n}[/itex]=[itex]\int^{1}_{0}[/itex][itex]\frac{1-(1-t)^{n}}{t}[/itex]dt.
Then I am supposed to rescale t so that I can apply the follow definition of the exponential function:
lim as n-->infinity of (1+[itex]\frac{z}{n}[/itex])[itex]^{n}[/itex]=[itex]\sum^{\infty}_{k=0}[/itex][itex]\frac{z^{k}}{k!}[/itex]=e[itex]^{z}[/itex]
I'm not seeing how I can use the first fact at all...
I assume that should be a capital N in your integral expression for [itex]\sum_{n=1}^{N} \frac{1}{n}[/itex]:
[tex]\sum_{n=1}^{N} \frac{1}{n} = \int_{0}^{1} \frac{1 - (1-t)^N}{t}dt[/tex]
Assuming that is the case, you could let [itex]u = Nt[/itex]; then your integral becomes
[tex]\sum_{n=1}^{N}\frac{1}{n} = \int_{0}^{N} \frac{1 - \left(1 - \frac{u}{N}\right)^N}{u} du[/tex]
and you could break this apart as [itex]\int_{0}^{1} + \int_{1}^{N}[/itex]. Dunno if this will get you anywhere but it seems promising.
Hmm... OK, this makes sense. What do you mean with the last part about splitting the integral up?
Well, I suggested that because one of the integrals you'll eventually need has 0 and 1 as its endpoints:
[tex]\int_{0}^{1}\frac{1 - e^{-t}}{t} dt[/tex]
So if you can justify interchanging the order of limit and integration,
[tex]\lim_{N \rightarrow \infty} \int_{0}^{1}\frac{1 - \left(1 - \frac{u}{N}\right)^N}{u}du[/tex]
will give you what you need.
That leaves you with the part from 1 to N:
[tex]\int_{1}^{N}\frac{1 - \left(1 - \frac{u}{N}\right)^N}{u}du[/tex]
which you could further split up as
[tex]\int_{1}^{N}\frac{1}{u}du - \int_{1}^{N}\frac{\left(1 - \frac{u}{N}\right)^N}{u}du[/tex]
Obviously the term on the left will be useful, given the definition of [itex]\gamma[/itex]. And the term on the right looks like it might converge as [itex]N \rightarrow \infty[/itex] to one of the other integrals you need, although that will also need to be proved.
OK, I've been able to work this out successfully. I'm stuck with two small things:
(1) How can I justify switching the order of integration and summation, as you mentioned?
(2) How do I show that the last integral converges?
Never mind, I was able to get the integral to converge. Now my only questions is what justifies switching the order? I know this is a subtle point, but I'd like to understand it.
A sufficient condition for switching the order is if the convergence is uniform, i.e., if
[tex]\lim_{N \rightarrow \infty} \frac{1 - \left(1 - \frac{u}{N}\right)^N}{u}[/tex]
converges uniformly in [itex][0,1][/itex]. This in turn will be true if and only if
[tex]\lim_{N \rightarrow \infty} \left(1 - \frac{u}{N}\right)^N[/tex]
Hmm, ok, great. That makes sense. How can I show that this is true? Weirestrass M-test?
