Verifying that a matrix T represents a projection operation
  • Level: Graduate
  • Thread starter Thread starter Seydlitz
    Matrix Projection
3 replies · 5K views
Seydlitz
Hello guys,
I want to verify or rather show that a given matrix ##T## does represent a projection from ##\mathbb{R^{3}}## to a particular plane, also lying in ##\mathbb{R^{3}}##. Would it be enough to pre-multiply that matrix to an arbitrary vector ##(x,y,z)##, and see if the resulting vector is orthogonal to the normal vector of that given plane, thus implying that the vector is projected successfully to the plane?
Or do I need to row reduce the matrix ##T## until I can see the basis vectors used in the original ##T##, and verify that they all lie on the plane? Or rather since I can also get the basis of the kernel, will showing that the basis of the kernel is parallel with the normal of the plane enough? Geometrically I imagine that the kernel space is all of the vectors that are orthogonal to the plane and their projection to that plane will be 0.
Thanks
Seydlitz said:
Hello guys,
This is necessary but not sufficient. If ##n## is normal to the plane and ##\langle n, Tx\rangle = 0## for all ##x##, then the image of ##T## is contained in the plane, but that doesn't necessarily mean that ##T## is a projection onto the plane. For example, consider the matrix
$$T = \begin{pmatrix}0 & 0 & 0 \\ 0 & 0 & 0 \\ 0 & 0 & 1 \end{pmatrix}$$
This matrix has the property that ##\langle n, Tx\rangle = 0##, where ##n = \begin{pmatrix}1 \\ 0 \\ 0 \end{pmatrix}## and ##x## is any vector. So the image lies in the plane whose normal vector is ##\begin{pmatrix}1 \\ 0 \\ 0\end{pmatrix}##. But it is not a projection onto that plane because the image only has dimension 1.
For another example, consider the matrix
$$T = \begin{pmatrix}0 & 0 & 0 \\ 0 & 2 & 0 \\ 0 & 0 & 2 \end{pmatrix}$$
Once again, we have ##\langle n, Tx\rangle = 0##, where ##n = \begin{pmatrix}1 \\ 0 \\ 0 \end{pmatrix}## and ##x## is any vector. The dimension of the image is correct (2), but this is still not a projection because it stretches vectors lying in the plane, e.g. it maps ##\begin{pmatrix}0 \\ 1 \\ 0\end{pmatrix}## to ##\begin{pmatrix}0 \\ 2 \\ 0\end{pmatrix}##. So you also need a constraint ensuring that no such stretching (and also no rotating) occurs. This is neatly captured by the condition ##T^2 = T##. Indeed, a matrix represents a projection if and only if it satisfies ##T^2 = T##.
So to summarize, if you want to show that a 3x3 matrix is a projection onto a particular plane, you need to verify all of the following:
  1. ##T^2 = T##, so ##T## is a projection
  2. ##\dim(\ker(T)) = 1## or equivalently, ##\dim(\text{im}(T)) = 2##, so ##T## projects onto a plane
  3. ##\langle n, Tx\rangle = 0## where ##n## is normal to the plane and ##x## is arbitrary, so ##T## projects onto the specified plane
You can find equivalent conditions which will allow you to do less work. [strike]For example, you can replace condition 3 with ##Tn = 0##.[/strike] [correction: If condition 3 is replaced with ##Tn=0## then not only is ##T## a projection, it is in fact an orthogonal projection.] But the basic idea remains the same.
Thanks for the comprehensive information jbunniii, I really appreciate it.
By the way I just realized the fact that the kernel space of a projection matrix is orthogonal to the image of the the projection. Is this true in general? For example if I have a subspace ##W## and a linear transformation from a vector space ##V## to ##W##. Can we consider the kernel of that transformation as the orthogonal complement of ##W##?
Actually, that's only true of orthogonal projections. For general projections, it need not be true. Consider for example
$$T = \begin{pmatrix}0 & 0 \\ c & 1 \\ \end{pmatrix}$$
This is a projection matrix, because ##T^2 = T##. The image is the subspace consisting of all scalar multiples of ##\begin{pmatrix}0 \\ 1 \end{pmatrix}##. The kernel is the subspace consisting of all ##\begin{pmatrix}x \\ y \end{pmatrix}## satisfying ##cx + y = 0##, or in other words, all scalar multiples of ##\begin{pmatrix}1 \\ -c \end{pmatrix}##.
You can think of ##T## as a source of light aimed in the direction of ##\begin{pmatrix}1 \\ -c \end{pmatrix}##, which projects a given vector onto its "shadow" on the image subspace. If the source of light is directly overhead (##c = 0##) then it's an orthogonal projection, otherwise it's called an oblique projection.
