Very basic website -- scraper "'str' object is not callable"
  • Topic: Python
  • Thread starter Thread starter Greg Bernhardt
9 replies · 3K views
TL;DR
Making a very basic web scraper and I have the error line 48 'str' object is not callable, and I can't figure it out.
Learning Python and this is a first attempt at a project.
[CODE lang="python" highlight="48"]import urllib
import requests
from bs4 import BeautifulSoup, Comment
# desktop user-agent
USER_AGENT = "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.14; rv:65.0) Gecko/20100101 Firefox/65.0"
# mobile user-agent
MOBILE_USER_AGENT = "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.125 Mobile Safari/537.36"
getkeyword = "plugin"
query = "wordpress plugin"
query = query.replace(' ', '+')
URL = f"https://google.com/search?q={query}"
headers = {"user-agent": USER_AGENT}
resp = requests.get(URL, headers=headers)
if resp.status_code == 200:
soup = BeautifulSoup(resp.content, "html.parser")
results = []
links= []
for g in soup.find_all('div', class_='r'):
anchors = g.find_all('a')
if anchors:
links.append(anchors[0]['href'])
else:
print("Google may have blocked you, try again in an hour")
i=0
for num in links:
URL = links
if soup.find('title'):
title = soup.find('title').text
if soup.find('h1'):
h1 = soup.find('h1').text
if soup.find('h2'):
h2 = soup.find('h2').text
bodytext = soup.find('body').text
print("#" + str(i+1) + ": " + links)
if title:
print("Title: " + title)
if h1:
print("H1: " + h1)
if h2:
print("H2: " + h2)
if getkeyword in bodytext:
print = ("Keyword: Yes")
else:
print = ("Keyword: No")
for comments in soup.findAll(text=lambda text:isinstance(text, Comment)):
getComments = comments.extract()
if "Yoast" in getComments:
print("Yoast: Yes")
break
print("\r\r")
else:
print("Site is unavailable")
break
i += 1
del links[/CODE]
A bit of Googling suggests that this can happen if you've defined a variable called str before running your script. Then python thinks you are referring to this variable and wonders why you are trying to call a variable. Try adding del str to the top of your script and running it. If that works, you should be able to remove the line you just added.
jedishrfu said:
Line 58 and 60 you redefined print as a string.
Yes, I think that's it. I assume the intent was to have those lines print things, not set the variable "print" equal to things.
Ah - I missed that. As per the previous two comments, you've stored a string in a variable called print. When you then try to call print the second time around the loop, python tries to call that string, which doesn't work.
I haven’t tested your code on Pycharm but it might flag this kind of error so you can fix it sooner. I know it can flag code that violates the Pep rules.
UPDATE: I tested it on the PyCharm IDE and PyCharm underlined the print word and gave the warning that it shadows a built-in name "print". Additional commentary mentioned len and list as other commonly shadowed built-in names.
I did run it on Pythonista on iOS and it showed the print to be a keyword but didn’t warn me until I ran it And got your error.
With respect to variable naming, I always strive to use camel case Or underscores and to never use a single English word like print. Sometimes I'll keep it simple using short one letter variables for intermediate results like s1 or s2 for strings.
jedishrfu said:
i did run it on Pythonista on iOS and it showed the print to be a keyword
"print" isn't a keyword in Python 3. In Python 2 lines 58 and 60 in Greg's script would have been a syntax error.
Curiously, even in Greg's listing the pretty printer plugin Geshi shows "print" highlighted as a keyword likely due to the fact that python2/3 is mapped to a generic python in the pretty printer plugin.
Woohoo that was it! Always the silly things for me! Thanks!
