Vi = 100km/h Vo=0km/h incline 15°. how far?
  • Thread starter Thread starter twenty5
    Incline
The problem involves a vehicle rolling up a 15° incline with an initial velocity of 100 km/h (27.77 m/s). The objective is to determine how far the vehicle will roll up the hill before coming to a stop, without being provided the time or mass of the vehicle.
  • Participants discuss the possibility of using conservation of energy, questioning the need for mass in the calculations.
  • Some suggest calculating the time it takes for the vehicle to stop and exploring the effects of gravitational acceleration on the vehicle's motion.
  • There are inquiries about how to incorporate the incline into the equations of motion and the components of gravitational acceleration.
  • One participant mentions using kinematic equations and expresses uncertainty about how to apply the incline in their calculations.
  • Another participant proposes decomposing gravitational acceleration into components relevant to the incline.
The discussion is ongoing, with various approaches being explored. Some participants have made attempts to calculate time and distance, while others are clarifying concepts related to gravitational components and kinematics. There is no explicit consensus on the correct method or solution yet.
Participants note the absence of certain information, such as mass and time, which complicates the problem. The discussion also reflects on the assumptions regarding gravitational acceleration and its components in relation to the incline.
twenty5
I'll just sum the question up:
A vehicle is on an incline of 15° and has velocity initial of 100km/h or 27.77
m/s and is left in neutral to roll up the hill -which is inclined at 15°. How far will it roll up the hill?
I tried going with Vf - Vi = d / t
but I'm not even given time in the question... T_T
I absolutely need some help here. If someone can just direct which direct to go first that would be great. thanks!
Im thinking this has to do with conservation of energy... but I don't have a mass :/
You can figure out the time it takes it to stop, what is the velocity when it has reached the farthest up the hill?
what kind of acceleration affects the vechicle?
I could? let's see... Vf - Vi = d / t
I don't have the distance though... Vf = 0
Vo = 27.77m/s
gravity would affect the vehicle. So I would use A = V/t
Now, I would substitute V =d/t into A = V/t and I would end up with t... would this be correct?if so, how will the 15° come into play?
well I diid all of that and I 2.83 seconds. I used that and stuck it into v = d/t and I got d = 78.59m. Can you please check to see if this is the correct answer? please and thank you ^^
Yes you need to use that we have an incline
I started out with the formula: v=vi+at, do you know this formula?
Pollux said:
I got it to d=152m, and I think that's correct. Yes you need to use that we have an incline, I used it for the acceleration.
would that be
A = (Vf - Vi) / t
AT + Vi = Vf
how would one use the incline part?
since gravity is going straight down vertically, there wouldn't really be any components other than 9.81 :S
Acctualy you can split the gravitational acceleration up into its components, so how much of that acceleration is in the direction of vi?
Make a picture and you can see how to get its components.
I made a drawing but it's point straight down :/
the only other way I would get a component for the gravitational acceleration would be if I had made it perpendicular to the 15° incline :(
Well you can decompose the acceleration in a component that is perpendicular to the 15 degrees and a component that in the opposit direction of the initial velocity.
The perpendicular component would be g*cos 15, but you want the other one that is in the direction of motion.
About the formula befor. It comes from that
dv/dt=a
http://en.wikipedia.org/wiki/Kinematics#Kinematics_of_constant_acceleration here you can see how its found.
mmk. Because I was taught that the gravitational acceleration (g) is always doing straight down :) but I'll give it a go with it being perpendictular to the 15°. thank you very much my friend ^^
The gravitational acceleration is allways pointing down towards Earth center of mass, but that does not mean we can't split it up into components, for exampel if you want to split it up into its xyz components were z points up you would get a=(0,0,-g).
In this case we want to split it up into a component that's perpendicular and a component that's in the direction of the motion, for this we get that
a=(-g*sin 15,g*cos 15)
were the last entry is for the perpendicular component. You could write out the initial velocity in this basis as well as vi=(vi,0).
Now we just care about the motion that goes on up and down the hill, simply because we know that this is the only place were motion happens because the problem is stated as such. You then get that
v=vi-(g*sin 15)*t.
Seems to me that the easiest approach would be by setting the ke = pe , the mass will cancel so you don't need it. You have the inital velocity, solve for height, use trig to find the distance you need,
  • · Replies 24 ·
