Vintage EEG Gain compared to modern voltmeter
11 replies · 2K views · last reply
Awwtumn
Front view of a light grey BrainMaster box with four coloured input terminals on top: red, green, black and yellow, plus a blue one.
Photo of a light grey box-shaped device labelled BrainMaster on its top surface, with a serial port connector visible on one end and a red cable at the other.
Green printed circuit board labelled BrainMaster 96 (c)1996 Thomas F. Collura, Type 1 Version C, with op-amps, resistors, capacitors, a large socketed IC, a 9-pin serial connector, and a crystal oscillator.
Page from a device submission document comparing the BrainMaster Type 2E EEG with the NRS-2D and Stoelting AT62 devices, with a table of parameters such as gain, sampling, input impedance and interface.
I got from my drawer last night a vintage Brainmaster 2E I bought late 1990s that I used only a few times during that period. It has serial port at back. I don't know if it will work using a USB to serial port adapter connected to my laptop. Do you think it will work?
My question concerns the gain of the amplifier and the noise. It says above:
Notch Filtering: 40 Hz cutoff
Common Mode Rejection >100 dB
Gain 20,000
Sampling 8 Bit
Input Impedance 10 M ohms
How does it compare say to your voltmeter? What is the gain of a regular voltmeter? It has this chip.
Close-up of a square surface-mount chip on a green circuit board, labelled MC68HC711E9CFN2, 5C47M, SSLY9827, with a Motorola logo.
Familiar with it?
I just want to know how it compares to modern amplifier and whether it's worth taking the trouble to maybe buy an old pc to run it. Is it very ancient and maybe the gain of regular voltmeter is double it? Or still much less?
Brainwaves are not static in time. How do you propose to use Voltmeter?
Is this part of your EEG/Monopole Detector idea? If so, it's better to tell us what you're trying to do rather than dropping bits and pieces like breadcrubs.
Thread is locked temporarily so I can discuss some safety issues with the OP...
(if you aren't careful with the electrical isolation to EEG electrode pads that are connected to your scalp, bad things can happen; don't ask me how I know this...)
  • Wow
After a PM discussion with the OP, he is not trying to use this for a medical application. Thread is reopened for now.
@Awwtumn -- Can you address V50's question please? Thanks.
Is this from personal experience or was there an unsuspecting victim?
I told you not to ask me about this! :wink:
It was on myself -- I never would have tried what I did on another person, even with their permission.
Now back to our regularly-scheduled programming. Nothing to see here folks, move along...
  • Haha
I think the serial interface can communicate with your modern computer if you buy the right adapter (I would be shocked if it wasn't RS-232). This is a pretty common problem and can be easily tested with a terminal app.
However, I doubt that the original SW will work, if you still have it. Lots of stuff written for Windows 3.1, Windows 95, etc. are toast now. IDK, maybe if you install a virtual machine? Writing your own code would require knowing what to say to this device, you'll need their SW interface docs, which I'm sure they never published (or even wrote).
So how many beers do we have to buy you to hear it? :-p
Sorry, not actually moving along, am I? Do I get some points for that transgression?
  • Haha
I don't know how to explain it to you. But I'll try. You are giving me the choice of either not explaining everything and not getting replies or explaining it and possibly getting the thread locked. I'll take risk in explaining because maybe some of you can comprehend this.
To start. The Big Bang is complex. Although some want to make it simple by rigid Newtonian residual elemental thinking.
For example. Before symmetry breaking when the electroweak force was still one at high temperature (which we have duplicated at the particle accelerators). Does the force anticipate that at some point we would use laptop and internet using electrical and electromagnetic signal. Yes. Big Bang is smart and not just some random explosion of spacetime and matter.
Could Big Bang be all about temperature? Electroweak may use it. But for the missing monopoles problem. Big Bang could hide it in the hidden sector or dark matter. And it may not only be by high temperature that it existed, but by some other means.
Look. The universe shared with us the supernal life, hence we share with it the supernal power.
What I'm trying to do is to summon the monopoles from the dark sector by creating vacuum domain in my table. Or to give you direct idea, low temperature symmetry breaking. The ability to have consciousness may be a fundamental aspect of the universe, right there at the Big Bang, we can refer to it as fundamental. Some physicists believe it like for example in the debate whether consciousness can collapse wave function and countless others.
Heck. I just heard the above from a physicist. So just want to build monopole detector to duplicate the experiment and see if I could also detect the monopoles like he did. Most physicists don't believe in low temperature symmetry breaking of some kind, so totally ignore doing any experiment of that nature. What if consistent monopoles can be produced this way instead of that rare 1982 valentine monopole detected by the 8 loop superconducting detector (the space it is housed in may have temporary symmetry breaking as a result of residual leak from another location, that's why it got a 5 sigma monopole event.
Realize guys that the Big Bang is more complex than all the theories we have. Remember the James Webb telescope has revealed that galaxies are more like fully formed right after the Big Bang and didn't evolve from current model.
Also you will notice that Dark Matter dynamics is not consistent, some cosmic object having the behavior of dark matter, some more like modified gravity. This may be because of another dynamics at play such as a modified vacuum or conditioned space. What I mean is the universe is more complicated than you can possibly imagine.
I hope the above descriptions get you in the mood now for my particular project.
Come on. If I can't detect monopoles, then no problem. At least I tried. In high school physics lab, they have dynamos and electromagnetic. Trying them out is part of learning. So trying out a monopole detector is part of learning too.
Hutchphd. Are there no voltmeter that is like oscilloscope in which it can sample it many times a second? What is gain of a normal voltmeter? I just want to know if my Brainmaster 2E is already outdated in terms of amplifier gain and instead of buying old 486, i'll just get oscilloscope that is sensitive enough to track monopoles that has frequency components too. (Before this thread is locked again, please give me some technical info about this. Thank you).
  • Haha
Nope. Vaya con Dios; Hasta la Vista.
