Violin frequencies and harmonics
The discussion focuses on the physics of violin strings, specifically the A and D strings tuned to 440 Hz and 294 Hz, respectively. The fundamental wavelength of the A string is calculated as 0.64 m, while the wavelength of the D string when played is 1.17 m. The third harmonic frequency of the D string is determined to be 882 Hz, and the second harmonic frequency of the A string is 880 Hz, resulting in a beat frequency of ±2 Hz. The calculations utilize the wave equations for strings and sound propagation in air.
  • Understanding of wave equations: f_n = n(v/2L) and λ_n = 2L/n
  • Knowledge of sound velocity in air (343 m/s)
  • Familiarity with harmonic frequencies and overtones
  • Basic principles of string instruments and their tuning
  • Explore the relationship between string length and frequency in string instruments.
  • Learn about the physics of sound waves and their propagation in different mediums.
  • Investigate the concept of beat frequencies in acoustics.
  • Study the harmonic series and its application in musical tuning systems.
Musicians, acoustics students, physics enthusiasts, and anyone interested in the principles of sound production in string instruments.
toothpaste666
A violin has four strings that are 32 cm long and are typically tuned to concert G, D, A, and E (196 Hz, 294 Hz, 440 Hz, and 660 Hz).
A)What is the wavelength of the fundamental mode of oscillation on the A string?
Sketch the waveform.
B)What is the wavelength of the sound in air when the D string is played (at 294 Hz)?
Assume that the velocity of sound in air is 343 m/s.
C)Calculate the frequency of the third harmonic (second overtone) on the D string
and the second harmonic (first overtone) on the A string. You will find that the
harmonics have similar frequencies. What is the beat frequency between the two
harmonics?
f_n = n(v/2L)
(lamba_n) = 2L/n
A) for the fundamental wavelength
lambda = 2L = 2(.32m) = .64 m
the picture is one standing wave over the length of the string
B) v= lambda * f
lambda = v/f = 343/294 = 1.17 m
C) for the D string. to find v we use the fundamental frequency
f = v/2L
294 Hz = v / .64m
v = .64 (294) = 188.16
for the third harmonic
f_3 = 3(v/2L) = 3(188.16/.64) = 882 Hz
for for A string
fundamental
f = v/2L
440 = v / .64
v = .64(440) = 281.6
second harmonic
f_2 = 2(281.6/.64) = 880 Hz
so the beat frequency is +/- 2 Hz
Your solution looks correct to me. Although for part C you could have found the frequencies of the Nth harmonic easier by just multiplying the fundamental frequency by N.
ah yeah you are right. thank you!
13K
