Visualizing the Area of a Triangle with Varying Angles
  • Thread starter Thread starter zeion
    Area Triangle
9 replies · 2K views
zeion
Show that for all [tex]\theta \epsilon (0, \pi)[/tex], the area of a triangle with side lengths a and b with included angle [tex]\theta is A = \frac{1}{2} a b sin \theta[/tex]. (Hint: You need to consider two cases)
I have just begun working on this problem.. not really sure where to start.
Does [tex]\theta \epsilon (0, \pi)[/tex] mean that the angle is > than 0 and < than pi?
Am I supposed to show that when the angle is less than or greater than the condition then the equation to find area is not valid?
Yes, that's what (0,pi) means. The only cases where the area is not ab*sin(theta) is where sin(theta) might be negative. They aren't in (0,pi). What's the area in that case?
zeion said:
The area is bh/2
They want you to give an answer in terms of the sides a and b. Not the base and the height.
Can you give me a little more hint -_-;
What are the two cases that I need to consider?
Use trig and A=bh/2. What's h in terms of a and the included angle? Draw a right triangle. And I'm really not sure what the 'two cases' they are talking about are.
sin(theta) and sin(180-theta) are the same number. Aren't they?
There's a variety of ways to draw a picture to show sin(pi-x)=sin(x). Which sort did you have in mind? How do you picture sin(x)?
