Visualizing the Motion of Coins on a Rotating Scale
The discussion focuses on the dynamics of coins on a rotating scale after the support is removed. When the scale begins to rotate, the torque varies along its length, causing coins closer to the hinge to experience different forces than those at the end. The key point is that coins of negligible mass may not accelerate with the same force as the rod, leading to some coins appearing to "hang" in the air as they fall under gravity. Calculations reveal that while parts of the rod accelerate faster than gravity, coins not in contact with the rod will fall freely. Ultimately, the conclusion is that the correct visual representation of the scenario involves understanding the differing accelerations experienced by the coins based on their position on the scale.
Rahulrj
A uniform rigid scale is held horizontally with one of its end at the edge of the table and the other supported by hand. Some coins of negligible mass are kept on the meter scale.
As the hand supporting the scale is removed, the scale starts rotating about its edge on the table and the coins start moving. Which of the following would look closest to the situation if a photograph of the scale is taken soon after
2. Homework Equations
Torque = ##r \times F##
##L = r \times p##
Torque = ## \frac {dL} {dt}##
This problem looked trivial until I tried to reason why the different options given would not be correct. This is how I thought about. Initially coins are at rest supported by reaction force provided by the hand. Now when the hand is removed, there is going to be a moment about the hinged part as a result of change in angular momentum. The torque is highest at the ends due to the length of the arm and lowest at points closer to the hinge. Also I think it is fair to assume that friction is greater than the force pulling it to the right on the coins closer to the hinge as it is about the situation immediately after the hand is removed and therefore I can conclude the coins are going to stick to the rod. However I am not able to come to conclusion regarding the coins at the right end especially trying to reason why option C and B could or could not be possible. Also I could not get my reasoning correct as to why the coins should separate from the right end as shown,
if the coins are of negligible mass then they remain to hang in the space along straight horizontal line after the rod has fallen down
zwierz said:
if the coins are of negligible mass then they remain to hang in the air along straight horizontal line after the rod has fallen down
Why should it remain in the air? Also there are three options that show coins in the air so which one among them?
The correct formulation of this problem should be as follows. A uniform rod of mass ##M## and length ##l## is held horizontally by its right end while the left end can rotate in a perfect hinge. There is a chain of small identical coins on the rod. The mass of the whole chain is ##m##. Find acceleration of the points of the rod right after its right end has been released. The rod is smooth.
I do not understand how finding acceleration is relevant to the problem. Nevertheless, for the rod I can write
##Mv^2/l =Mgsin\theta ##
Not quite sure how to model the equation for chain.
I think , all such coins lose contact with the stick where the underlying contact surface on the stick move with an acceleration greater than 'g' ( acc. due to gravity ) after the hand is removed .
An important/interesting exercise for you would be to
1) Calculate the acceleration of the tip of the stick of mass M and length L just after hand is removed ? Note that coins are very light , so you can neglect their effect .
2) Now , find a point on the stick whose acceleration is 'g' ?
After you have solved the above two you would get length of part of the stick whose linear acceleration is greater than 'g' and part whose acceleration is less than 'g' .
This should enable you to spot the best option .
Let ##\rho=m/l## be the density of the chain of coins; see post #4. Let ##dm=\rho dx## be infinitesimal element of this chain. By ##N(x)dm## denote the reaction force that acts on ##dm## from the rod.
By ##J=Ml^2/3## denote moment of inertia of the rod about ##O##; ##\epsilon## is angular acceleration of the rod.
So we have
$$J\epsilon=-Mgl/2-\int_0^XxN(x)\rho dx,\quad a(x)dm=N(x)dm-gdm;\qquad (*)$$
here ##a(x)## is the vertical part of acceleration of the rod's point with coordinate ##x,\quad a(x)=\epsilon x##; ##X## is ##x-##coordinate of the point at which chain leaves the rod. The second equation of (*) holds for ##0\le x\le X##.
From the second equation of (*) we have ##N(x)=\epsilon x+g## and thus ##X=-g/\epsilon.##
Substituting these formulas to the first equation of (*) we have the following cubic equation on ##\epsilon##
$$J\epsilon^3+\frac{1}{2}Mgl\epsilon^2+\frac{1}{6}\rho g^3=0.$$ It is easy to see that this equation has a unique real root ##\epsilon_*## and ##\epsilon_*<0##.
Okay I can calculate the tangential acceleration as follows,
## a_t = r\alpha## and torque ##\tau = I\alpha##
##\alpha = \tau/I##
##\tau = r \times F = LMg/2## (uniform rod, weight approximated to act at centre half way along)
##I = ML^2/3##
##\alpha = \frac{3g}{2L}##
## a_t = L \frac{3g}{2L} = 3/2g##
From the above calculation, I can say ##a_t = g## is at ##\frac{2L}{3}##
So two third of the length of rod from the hinge has linear acceleration less than g and one third has it greater than g.
Going by that, option B should be the correct one.
However I have got a doubt, assuming that coins have negligible mass, wouldn't all the coins experience an acceleration the same as all the points on the rod? So why would some be left hanging in the air as opposed to going along with the rod?
Right.
Does that change their acceleration in free fall?
Consider the forces on one of those coins on the right. Is it possible that these forces will cause the coins to accelerate as fast as the rod?
Why ?
They are not hanging in air . Rather all those coins not in contact with stick I.e those in a horizontal line , are in free fall . They are accelerating downwards with acceleration 'g' :smile:
The coin experiences gravity force mg. If we neglect m that is m=0 then for such a coin there is no gravity, it will hang in air. The statement of the problem is incorrect.
I agree .
Coins are of negligible mass , not massless .
Likes haruspex
haruspex said:
Right.
So considering a coin at the right end,
##N-mgcos\theta = -ma##
##N = m (g cos\theta-a)##
therefore ##g'=gcos\theta-a## not sure if this is right but it tells me the coins experience a lesser acceleration and thereby I can conclude they experience a lesser force?
As in you analysis in post #8, you only need to consider the initial acceleration, so θ=0.
Rahulrj said:
g′=gcosθ−a
What is g'? You already have a for the acceleration the coins experience.
Those are just words. Write exact equations then neglect some terms in the equations then obtain approximate equations then it will be matter for discussion
Okay yes, so the equation will be N=m(g-a)
g' is from the normal force on the coin, (mg').
zwierz said:
That are just words. Write exact equations then neglect some terms in the equations then obtain approximate equations then it will be matter for discussion
There's nothing to discuss. It would have been clearer if the question had said the mass of the coins is negligible compared with that of the rod, but Vibhor's reading is obviously correct.
Likes Vibhor
Yes, but you are interested in the value of a, so what's a better way to write that?
What limits can you place on N?
for acceleration to be g, N should be zero but that does not convince me. Putting a limit on N, we make it a case for free fall rather than it being a case of free fall as a result of the formulations.
Not sure what you mean. Do you mean the equations? If so, that's why I asked you what limits can be placed on N.
I am also not quite sure what you meant by the limits on N. To me N= m(g-a) tells that coins are going to experience a lesser force and I don't know how to infer acceleration unless I take it to be a case of free fall and put N=0.
Can it be negative?
haruspex said:
Can it be negative?
unless 'a' is greater than g, it cannot be negative.
You do not need that to answer the question. Can the normal force from the scale on the coins be negative? Can the normal force from the floor on your feet be negative?
Normal force acts upwards in those cases and therefore it cannot be negative.
Right (unless glue or nails are involved). So rearrange your equation in the form a = ... and use the fact that N≥0 to find a limit on a.
Okay now I get what you meant!
a = mg-N/m
a = g-N/m m is negligible
therefore a = g.
but if m where not negligible how would I infer 'a' in that case?
Rahulrj said:
a = g-N/m
Right.
Rahulrj said:
m is negligible
No, that is not going to help. m is small, but we don't know what it is in relation to N.
Use the fact that N≥0, as I told you.
haruspex said:
Right.
From that fact I can only say 'a' is going to be negative or do you mean a substitution for N?
  • #31
I get the feeling you do not know how to work with inequalities.
You have a = g-N/m and N≥0. So -N/m≤0. Adding g to each side, g-N/m≤g.
Likes Rahulrj
  • #32
Alternatively ,
since N≥ 0 , m(g - a) ≥ 0 or a≤g
Likes Rahulrj
  • #33
I have not had much practice with inequalities so when I come across a problem that requires it, that idea does not strike through although I know how to work out inequalities such as this. Also how would the equation vary if I was to write it for a coin that is placed less than 2/3 L of the rod?
Specifically what in this equation, N-mg=-ma would change?
  • #34
Nothing in that equation would change. It would still be true that since N≥0 it must that a ≤ g.
The difference would be that the acceleration of the part of the rod it is on would be < g, implying N > 0.
Likes Vibhor
  • #35
So a more specific value for acceleration cannot be inferred then? or is it correct to write the normal force on the coin at the part of rod with the rod's value of g at that point since they are going to be sticking onto the rod?
  • #36
I think you mean the rod's value of acceleration at that point.
Yes. If at some point less than 2L/3 from the axis the normal force is zero then the coin must be accelerating faster than the rod, which is not possible. So N>0, which means the coin must be in contact with the rod.
  • #37
I am not sure if you got what I meant, for example I am interested in finding acceleration that coin experiences at say L/3
so the equation will be, N - mg = -ma and my doubt is whether if it is correct to write a = g/2? as it is the acceleration rod has at that point
  • #38
Yes, that must be right. If it were more, it would penetrate the rod; if it were less it would lose contact with the rod, making N zero, so then it would fall at rate g and immediately catch up to the rod again.
Likes Rahulrj
  • #39
There is a funny counterintuitive fact: if ##m## is a total mass of all coins then $$|\epsilon|\sim const \,m^{1/3},$$ as ## m\to\infty## where ## \epsilon## is angular acceleration of the rod right after it is released. Other parameters are fixed.
Likes haruspex
