Voltage as the cause of motion of charges?
The discussion centers around the relationship between voltage and the motion of charges, particularly in the context of electric current and phenomena like lightning. Participants explore whether voltage can be considered the primary cause of charge movement or if other factors, such as the Coulomb force, play a more significant role. The conversation touches on theoretical and conceptual aspects of electricity, including the implications of electric fields and potential differences.
  • Some participants assert that voltage is often described as the cause of current, but question whether this is accurate given the role of the Coulomb force.
  • One participant claims that the Coulomb force is equivalent to the gradient of voltage, suggesting a relationship between the two concepts.
  • Another viewpoint emphasizes that current is related to voltage through Ohm's law and energy conversion processes, indicating that both current and voltage are interdependent rather than one being the sole cause of the other.
  • There is confusion regarding how voltage behaves with distance, with some participants noting that voltage decreases with distance while others argue that it can increase in certain contexts.
  • One participant introduces an analogy involving a charged plate and electric fields, discussing how potential and electric field strength interact and affect charge movement.
  • Another participant raises the point that higher voltage does not necessarily correlate with a stronger Coulomb force, questioning the assumption that higher voltage always leads to higher current.
  • Discussion includes the phenomenon of lightning, with participants exploring how high potential differences can lead to breakdowns in air and the creation of conductive paths.
Participants express differing views on the relationship between voltage and current, with no consensus reached. Some argue for voltage as a driving force, while others emphasize the role of electric fields and Coulomb forces. The discussion remains unresolved regarding the primary cause of charge motion.
Participants note limitations in their understanding of how voltage and electric fields interact, particularly in non-uniform fields and varying distances. There is also ambiguity regarding the definitions of voltage and electric field strength in different scenarios.
  • #31
gralla55 said:
Yes, if it is the same path. But if you have the same potential difference between the endpoints of a wire with length L, and a wire with length 2L, shouldn't the strength of the eletric field be half inside the second wire? The integral says that the work the field does along the path is the same. If the path is twice as long, the field would have to be twice as weak to get the same work.
Yes. If you use half the force over twice the distance then you have the same amount of work. In the equation ##-\int E\cdot ds=\Delta V## if s increases then E must decrease (all other things the same) for ΔV to stay the same.
  • #32
gralla55 said:
A voltage "by itself" is not enough to determine the strength of an electric field between two points, you have to also know the distance between the two points in question.
There is no such thing as "the strength of an electric field between two points", as far as I know. There is the strength of the E field at a point, ##|E|##, and there is the E field along a path, ##\int E\cdot ds##. Each is related to the voltage appropriately.
Suppose that you have a very strong uniform E field and a path perpendicular to the E field. Despite being strong, the E field does not drive any current along the path because ##E \cdot ds=0##. It is only the E field along the path which drives current along the path.
  • #33
DaleSpam:
Strictly speaking, you are correct of course. However, if the magnitude of the electric field X at every point between point A and B were larger than the magnitude of the electric field Y on every point between point C and D, it's common to refer to field X as the "stronger electric field", even though it is unpresise as a mathematical description.
DrZoidberg:
Thanks a lot for the link! Great diagrams and drawings. One thing that's still not clear to me, is if the magnitude of an electric field inside a wire with DC current is taken to be constant everywhere in the wire?
  • #34
Yes, but as I pointed out above, if this is what you mean by the term then the strength of the electric field does not drive current along a path.
In the end, your textbook is correct, the voltage does drive it. You can also say the E field drives it, because of how the E field and the voltage are related.
  • #35
Voltage does not "drive current".
Claude
  • · Replies 21 ·
  • · Replies 58 ·
