Voltage compliance and load resistor range for BJT current source
  • Thread starter Thread starter Duave
    Compliance
18 replies · 3K views
Duave
Thank you for any help that you can offer.
Did I answer the questions?
What is the voltage compliance range of the current source?
Between what range of RL values will the circuit function as a current source?
https://scontent-a.xx.fbcdn.net/hphotos-ash3/t1.0-9/1488711_10151945891295919_440459508_n.jpg
VB = 1.6V
VE = 1.0V
IE = 1.0mA
IL = 1.0mA
VLimit = VCC - ILRE
VCE < V < VLimit
Minimum staturation voltage:
VCE (Sat) = 0.1V
compliance range is:
VCE < V < VLimit
VCE < V < VCC - ILRE
0.1V < V < 10V - 1V
0.1V < V < 9V
The range of load resistors can be found by:
iOUT = Vin/R
VCE/iE < R < (VCC - ILRE)/iL
0.1V/1.0mA < R < (10V - 1V)/1.0mA
100(ohm) < R < 9000(ohm)
Are answers? Are there any errors located?
Thanks again for your help.
Can you tell me why you think that for RL<100R this current source won't work?
Also calculate Vce for RL = 9K.
If you assume that transistor is in saturation region for Vce<0.1V. In this case the active region (Vce range) is indeed between 0.1V and 9V. But still you have incorrect resistor range.
Jony130 can you look at what I did and tell me where I went wrong?
Vce voltage is not the voltage that "appears" across RL resistor.
V_RL = Vcc - Vce - Ve. So for Vce = 0.1V --->V_RL = (10V - 0.1V - 1V) = 8.9V.
And if Vce = 9V --->V_RL = ??
I'm lost .
I knew my answers were incorrect.
V(limit) was said to be the maximum before saturation
so the compliance voltage range is okay.
the load resistance range is not
so what do I do? Cause I don't get this now
Do you see the difference between Vce voltage and voltage across RL resistor?
Vce is a junction voltage, The voltage across RL is a branch voltage,
But I don't understand this range business.
What does range mean with respect to Vce and RL?
Q1. What is the voltage across V_RL if Vce = 0.1V ?
Q2. What is the voltage across V_RL if Vce = 9V ?
See I confused because I wasn't given an RL value,
Ic = Ie only during the active region so I have no currents,
I'm stuck like a duck.
You don't need to know RL value. First we need to know V_RL voltage range. Next we can use this range to find RL value. The only think you need is to find V_RL range by using KVL and find V_RL voltage.
Vcc-(ILxRL) - Vce = 0
10V-(IL x RL) -0.1 = 0
9.9V -(ILxRL) = 0
9.9V = ILxRL
9.9V/IL = RL
9.9V/1.0mA = RL
9.9 k(ohm) = RL
You forget about Ve voltage.
Vcc-(ILxRL) - Vce -Ve = 0
10V-(IL x RL) -0.1 - 1V= 0
8.9V -(ILxRL) = 0
8.9V = ILxRL
8.9V/IL = RL
8.9V/1.0mA = RL
8.9 k(ohm) = RL
So is this the lower or the upper limit?
8.9V -(ILxRL) = 0
8.9V = ILxRL
8.9V/IL = RL
8.9V/1.0mA = RL
8.9 k(ohm) = RL
Finally, some good work.
What do you think ?
